I have a notebook: Clevo (model M570RU) There is the GeForce 8700M GT card. Can I upgrade to 8800M GTX?
    Problem Solver:
  • 13 Answers
You can surely upgrade to 8800m GTX on your Clevo. It works fine.
Posted on Jan 23, 2009
Change graphics card vostro 1710
Some laptops do have a graphics card that is mounted to the motherboard, with it's gold plated contact pins.
The pins slide into an expansion slot on a circuit board, that mounts to the motherboard.
Removable, therefore deemed may be upgradable.
Most however are like Chris stated, and are mounted to the motherboard with a BGA surface mount.
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll down, click on the Red ->
Take a few minutes to view the IR 650 demo video. (5 minutes)
Shows you the IR 650 BGA Rework Station at work, but more importantly shows you the BGA surface mount; Solder Balls, and Copper Pads.
http://en.wikipedia.org/wiki/Ball_Grid_Array
IF, your Dell uses Integrated Graphics, the motherboard chipset is an Intel GM965 chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_mobile_chipsets
Intel GMA X3100 integrated graphics.
http://en.wikipedia.org/wiki/Intel_GMA#GMA_X3100
Means the G.P.U. is integrated in the Intel GM965 motherboard chipset.
Nope. No upgrading of that baby.
IF, your motherboard chipset is an Intel PM965 chipset, it uses Discreet Graphics through a PCI Express bus,
Means the laptop comes with an Nvidia GeForce 8600M GT graphics chipset,
http://www.dell.com/us/en/bpi/notebooks/vostronb_1710/pd.aspx?refid=vostronb_1710&s=bpi
Here we can see the Dell Vostro 1700 series of Notebook PC's, uses a separate graphics (Video) card, (IF your laptop came with this option)
http://www.ebay.com/itm/Dell-DY445-VOSTRO-1700-INSPIRON-1720-nVidia-GeForce-8600M-GT-Video-Card-256Mb-/120955693339?pt=PCC_Video_TV_Cards&hash=item1c2985691b
The green circuit board of the Nvidia GeForce 8600M, you can barely see.
The aluminum metal plate on top of it, is attached to the copper Cooling Tube, then to the finned rectangular Heatsink.
[Heat is drawn from the graphics chipset {GPU} on the graphics card, to the large aluminum metal plate. The plate absorbs the heat, then transfers the heat to the copper Cooling Tube.
The Cooling Tube is a slightly flattened copper pipe, sealed on both ends, and filled with Nitrogen gas.
The Cooling Tube absorbs the heat from the plate, then transfers the heat up to the finned rectangular Heatsink.
The finned Heatsink absorbs the heat, then radiates it away with it's thin fins. Air flow from the Fan Assembly, helps carry away heat from the fins of the finned Heatsink ]
This is what the Nvidia GeForce 8600M looks like, not attached to the cooling assembly,
http://www.ebay.com/itm/ASUS-NVIDIA-GeForce-8600M-GT-8600mgt-512-MB-512M-DDR2-MXM-II-Graphic-Card-f-F8SV-/330701665242?pt=PCC_Video_TV_Cards&hash=item4cff5af3da
You can see plainly that this is a graphics/video card.
Four mounting holes, and gold plated contact pins on the bottom.
The actual term is graphics ADAPTER card. The Brownish/Red square you see in the middle/bottom, is the graphics chipset.
[ The actual G.P.U. or Graphics Processing Unit, is the black chipset in the middle of that brownish/red square, has Nvidia in white on it, and white characters on the bottom -
***-***-XX.
X's used because I can't read it.
The brownish/red square around the GPU is a small circuit board.
ALL GPU's have to have a small circuit board, in order to mount to the motherboard, or a graphics adapter card. Also for electrically connecting the GPU to a motherboard, or graphics adapter card.
GPU,
http://en.wikipedia.org/wiki/GPU ]
In conclusion;
1) Depends on what Intel motherboard chipset you have, right off the bat.
Intel GM965 = No
Intel PM965 = Maybe
2) Intel PM965? Then your laptop should have the above Nvidia GeForce 8600M GT, with graphics adapter card, and cooling assembly.
2A) Does that mean you can change the GeForce 8600M GT?
Maybe. You need a BGA Rework machine, and better Nvidia GeForce graphics chipset. You're talking Ka-Ching here. $$$$$$$$$$
Probably have to stay within the same Fabrication Technology in nm.
(nm = NanoMeter. 1 Billionth of a Meter)
The 8600M GT is 80nm fab technology.
So is the 8700M GT.
When you get to the 8800M GTS, it changes to 65nm.
That's the architectural size. Doesn't state all the technological features that changed with it. (80nm to 65nm)
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_8M_.288xxxM.29_series
Means your BIOS program probably won't handle it, and doubt there is a BIOS upgrade for it.
3) Better graphics adapter card, and graphics chipset?
Again, that IMHO would only be an Nvidia GeForce 8700M GT, and NOT worth the trouble, believe me.
So that's it? No chance of upgrading your graphics? No, not so.
More information in an added Comment.
Regards,
joecoolvette
Aug 15, 2012 | Dell Vostro 1710 Laptop
Tip
A list of the compatible PCI-Express 16X Graphics cards for a PCI-Express...
Having trouble finding out which graphics card will work with your PCI-Express motherboard? Here is a list all PCI-Express graphics cards for AMD/ATI Radeon. This list is in descending order. (The top graphics cards from each manufacturer are more recent, have greater memory and are faster while the bottom are older, have less momory and are slower).
If your Motherboard supports PCI-Express X16 then here is a list of compatible ATI/AMD Radeon Cards.
AMD Radeon 6000 Series - (AMD Radeon HD 6870 and AMD Radeon HD 6850)
ATI Radeon 5000 Series - (ATI Radeon HD 5970, ATI Radeon HD 5870 Eyfinity 6, ATI Radeon HD 5870, ATI Radeon HD 5850, ATI Radeon HD 5830, ATI Radeon HD 5770, ATI Radeon HD 5750, ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5870, ATI Radeon HD 5550 and ATI Radeon HD 5450)
ATI Radeon 4000 Series - (ATI Radeon HD 4870 X2, ATI Radeon HD 4890, ATI Radeon HD 4870, ATI Radeon HD 4850, ATI Radeon HD 4830, ATI Radeon HD 4770, ATI Radeon HD 4600, ATI Radeon HD 4550, ATI Radeon HD 4300 and ATI Radeon HD 4200)
ATI Radeon 3000 Series - (ATI Radeon HD 3800, ATI Radeon HD 3600, ATI Radeon HD 3400)
ATI Radeon 2000 Series - (ATI Radeon HD 2900, ATI Radeon HD 2600, ATI Radeon HD 2400)
ATI Radeon X Series - (ATI Radeon X1950, ATI Radeon X1900 and ATI Radeon X1800)
If your Motherboard supports PCI-Express X16 then here is a list of compatible Nvidia Cards.
GeForce 500 Series - (GeForce GTX 580)
GeForce 400 Series - (GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460, GeForce GTS 450, GeForce GT 440, GeForce GT 430, GeForce GT 420)
GeForce 200 Series - (GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250, GeForce GTS 240, GeForce GT 220, GeForce GT 210)
GeForce 9 Series - (GeForce 9800 GX2, GeForce 9800 GTX+, GeForce 9800 GTX, GeForce 9600 GT, GeForce 9600 GSO 512, GeForce 9600 GSO, GeForce 9400 GT)
GeForce 8 Series - (GeForce 8800, UltraGeForce 8800 GTX, GeForce 8800 GTS (640 MB, 512MB and 320 MB versions), GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT, GeForce 8500 GT, GeForce 8400 GS)
GeForce 7 Series - (GeForce 7950, GeForce 7900, GeForce 7800, GeForce 7600)
GeForce 6 Series - (GeForce 6800 Ultra, GeForce 6800 GT, GeForce 6800 GS, GeForce 6800, GeForce 6800 XT)
For a list of compatible AGP8X Cards for an AGP8X Motherboard click on this link to take you to my other tips page. http://www.fixya.com/support/r6784133-list_compatible_graphics_cards_agp8x
on Feb 10, 2011 | Computers & Internet
Hi. i have a compaq presario sr5025an. I have 2 gig of ram. I have the intel core 2 duo e4300 processor. I am after a grapics card. cheers.
To get the full specs of your mainboard go to: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00893006&lc=en&cc=au&lang=en&product=3401230&dlc=en#N198
This motherboard has 1 PCI Express x16 slot for a graphics card.
You could use:
Geforce 6 series (6800GT)
Geforce 7 series (GeForce 7950, GeForce 7900, GeForce 7800, GeForce 7600 ,
GeForce 7300, GeForce 7200 and GeForce 7100)
Geforce 8 series (GeForce 8800 Ultra, GeForce 8800 GTX, GeForce 8800 GTS, GeForce 8800 GTS 512, GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT and GeForce 8500 GT)
Geforce 9 series (GeForce 9800 GX2, GeForce 9800 GTX+, GeForce 9800 GTX, GeForce 9600 GT, GeForce 9600 GSO 512, GeForce 9600 GSO and GeForce 9400 GT
Geforce 200 series (GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250 GeForce GTS 240 and GeForce GT 220
Geforce 400 series (GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460, Geforce GTX 450)
With your system however I would recommend nothing greater than a Geforce GTS 250.
Please rate me high.
Thanks.
Nov 01, 2010 | HP Computers & Internet
What is the best pc graphics card? for blu-ray and 3d.
This is the list of Nvidia Gfx cards that can support blu-ray and 3dvision
NVIDIA GeForce Graphics Cards
GeForce 400/300 Series GeForce 200/100 Series GeForce 9 Series GeForce 8 Series 3D Gaming Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
GeForce GT 340
GeForce GT 330
GeForce GT 320 Desktop
GeForce GTX 295
GeForce GTX 285
GeForce GTX 280
GeForce GTX 275
GeForce GTX 260
GeForce GTS 250
GeForce GTS 240
GeForce GT 140 Desktop
GeForce 9800 GX2
GeForce 9800 GTX+
GeForce 9800 GTX
GeForce 9800 GT
GeForce 9600 GT Desktop
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce 8800 GTS
GeForce 8800 GT 3D Applications Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
GeForce GT 340
GeForce GT 330
GeForce GTX 295
GeForce GTX 285
GeForce GTX 280
GeForce GTX 275
GeForce GTX 260
GeForce GTS 250
GeForce GTS 240
GeForce 9800 GX2
GeForce 9800 GTX+
GeForce 9800 GTX
GeForce 9800 GT
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce 8800 GTS
GeForce 8800 GT 3D Pictures Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
All GeForce 300 series Desktop
All GeForce 200 series Desktop
All GeForce 9 series Desktop
All GeForce 8 series Blu-ray 3D playback* Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
GeForce GT 340
GeForce GT 330
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 295**
GeForce GTX 285**
GeForce GTX 280**
GeForce GTX 275**
GeForce GTX 260**
GeForce GT 240 Notebook
GeForce GTS 360M
GeForce GTS 350M
GeForce GT 335M
GeForce GT 330M
GeForce GT 325M
GeForce GT 320M 3D Movie file playback Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
All GeForce 200/100 series Desktop
All GeForce 8 series * Blu-ray 3D playback requires compatible Blu-ray 3D player software from companies such as CyberLink and Arcsoft. Please continue to check the 3D Vision product home page for more details on Blu-ray 3D support.
** Blu-ray 3D GPU decode acceleration is not supported on these models. Please insure that your CPU is fast enough to handle video decode (a quad-core CPU recommended)-->
And don't know about ati graphic cards which has these features. i'm sure i have given you a satisfactory answer.
For further any help or to thank me you can mail me on my email Ejaz89@live.com
Aug 08, 2010 | Computers & Internet
Is it possible to replace Nvidia 8400M GS
defenetly the chip of nvidia located on your motherboard will change. please specify motherboard mac and revolution for the same
Dec 22, 2009 | HP Pavilion DV9500Z Notebook PC
No solution found. I wonder if the solution exists. Anyway, here is the pb. no drivers for the following running on an hp pavilion dv9858 under Windows Xp i-Sound card: Intel 82801HBM ICH8M - High...
Follow the instructions at the bottom of this page for the sound card:
http://www.howtogeek.com/forum/topic/help-needed-to-find-device-drivers-for-win-xp?replies=8
for the video card: http://www.opendrivers.com/freedownload/284952/nvidia-geforce-8700m-gt-8600m-gt-8400m-gs-8400m-g-forceware-driver-176.37-windows-xp-x32-download.html
Apr 04, 2009 | HP Pavilion dv9700t Notebook PC
Notebook graphics card upgrade
  • Asus ROG STRIX GTX 1080 O8G GAMING. ...
  • MSI GeForce GTX 1070 GAMING X 8G. ...
  • EVGA GeForce GTX 1080 Ti Founders Edition. ...
  • Zotac GeForce GTX 1050 Ti 4GB OC Edition. ...
  • Nvidia GeForce GTX 1080 Founders Edition. ...
  • Nvidia GeForce GTX 1060 Founders Edition. ...
  • XFX Radeon RX 480
you can purchase any one and use it
May 15, 2017 | Philips i855 Cellular Phone
I have a e-GeF0rce 8600 GTS. My computer sees a NVIDIA GeForce 6150SE N FORCE 430.0. iS THIS A PROBLEM
Hello Baldarchi,
This is normal and how ever uninstall the current driver and install latest driver from the following link:
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/Nvidea%20video%20driver.exe
The above driver supports:
[DEV_0098] NVIDIA GeForce Go 7800 [DEV_0099] NVIDIA GeForce Go 7800 GTX [DEV_00C8] NVIDIA GeForce Go 6800 [DEV_00C9] NVIDIA GeForce Go 6800 Ultra [DEV_00CC] NVIDIA Quadro FX Go1400 [DEV_0144] NVIDIA GeForce Go 6600 [DEV_0146] NVIDIA GeForce Go 6600 TE/6200 TE [DEV_0148] NVIDIA GeForce Go 6600 [DEV_0149] NVIDIA GeForce Go 6600 GT [DEV_0164] NVIDIA GeForce Go 6200 [DEV_0166] NVIDIA GeForce Go 6400 [DEV_0167] NVIDIA GeForce Go 6200 [DEV_0168] NVIDIA GeForce Go 6400 [DEV_01D4] NVIDIA GeForce Go 7350 [DEV_01D6] NVIDIA GeForce Go 7200 [DEV_01D7] NVIDIA GeForce Go 7300 [DEV_01D8&SUBSYS_81E6104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81EF104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_81FD104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_8205104D] NVIDIA GeForce Go 7400 [DEV_01D8&SUBSYS_820F104D] NVIDIA GeForce Go 7400 [DEV_01D8] NVIDIA GeForce Go 7400 [DEV_01DA] NVIDIA Quadro NVS 110M [DEV_01DB] NVIDIA Quadro NVS 120M [DEV_01DC] NVIDIA Quadro FX 350M [DEV_0244] NVIDIA GeForce Go 6150 [DEV_0247] NVIDIA GeForce Go 6100 [DEV_0297] NVIDIA GeForce Go 7950 GTX [DEV_0298] NVIDIA GeForce Go 7900 GS [DEV_0299&SUBSYS_309F103C] NVIDIA Quadro NVS 510M [DEV_0299] NVIDIA GeForce Go 7900 GTX [DEV_029A] NVIDIA Quadro FX 2500M [DEV_029B&SUBSYS_309F103C] NVIDIA Quadro FX 1500M [DEV_029B] NVIDIA Quadro FX 1500M [DEV_029D] NVIDIA Quadro FX 3500 [DEV_0397] NVIDIA GeForce Go 7700 [DEV_0398&SUBSYS_81EF104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 [DEV_0398&SUBSYS_8205104D] NVIDIA GeForce Go 7600 [DEV_0398] NVIDIA GeForce Go 7600 [DEV_0399&SUBSYS_81FD104D] NVIDIA GeForce Go 7600 GT [DEV_0399&SUBSYS_8205104D] NVIDIA GeForce Go 7600 GT [DEV_0399] NVIDIA GeForce Go 7600 GT [DEV_039A] NVIDIA Quadro NVS 300M [DEV_039B] NVIDIA GeForce Go 7900 SE [DEV_0407&SUBSYS_01F11028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_01F21028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02281028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_02291028] NVIDIA GeForce 8600M GT [DEV_0407&SUBSYS_022E1028] NVIDIA GeForce 8600M GT [DEV_0407] NVIDIA GeForce 8600M GT [DEV_0408] NVIDIA GeForce 8600M GTS [DEV_0409&SUBSYS_019B1028] NVIDIA GeForce 8700M GT [DEV_0409&SUBSYS_019C1028] NVIDIA GeForce 8700M GT [DEV_0409] NVIDIA GeForce 8700M GT [DEV_040B&SUBSYS_30C3103C] NVIDIA Quadro NVS 320M [DEV_040B] NVIDIA Quadro NVS 320M [DEV_040C&SUBSYS_20D917AA] NVIDIA Quadro FX 570M [DEV_040C&SUBSYS_30C5103C] NVIDIA Quadro FX 570M [DEV_040C] NVIDIA Quadro FX 570M [DEV_040D&SUBSYS_019B1028] NVIDIA Quadro FX 1600M [DEV_040D&SUBSYS_30C3103C] NVIDIA Quadro FX 1600M [DEV_040D] NVIDIA Quadro FX 1600M [DEV_0425] NVIDIA GeForce 8600M GS [DEV_0426] NVIDIA GeForce 8400M GT [DEV_0427&SUBSYS_01F11028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F21028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_01F31028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02091028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02271028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02281028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_02291028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_022E1028] NVIDIA GeForce 8400M GS [DEV_0427&SUBSYS_9008104D] NVIDIA GeForce 8400M GS [DEV_0427] NVIDIA GeForce 8400M GS [DEV_0428&SUBSYS_9008104D] NVIDIA GeForce 8400M G [DEV_0428] NVIDIA GeForce 8400M G [DEV_0429&SUBSYS_01FE1028] NVIDIA Quadro NVS 140M [DEV_0429&SUBSYS_20D817AA] NVIDIA Quadro NVS 140M [DEV_0429] NVIDIA Quadro NVS 140M [DEV_042A] NVIDIA Quadro NVS 130M [DEV_042B&SUBSYS_01F91028] NVIDIA Quadro NVS 135M [DEV_042B&SUBSYS_01FE1028] NVIDIA Quadro NVS 135M [DEV_042B] NVIDIA Quadro NVS 135M [DEV_042D&SUBSYS_01FF1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024A1028] NVIDIA Quadro FX 360M [DEV_042D&SUBSYS_024B1028] NVIDIA Quadro FX 360M [DEV_042D] NVIDIA Quadro FX 360M [DEV_0530] NVIDIA GeForce 7190M / nForce 650M [DEV_0531] NVIDIA GeForce 7150M / nForce 630M [DEV_0532] NVIDIA MCP67M [DEV_0533] NVIDIA GeForce 7000M / nForce 610M [DEV_053F] NVIDIA MCP67M
Sep 12, 2008 | Computers & Internet
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
