Question about Aurora Electronics AS1018CD Shredder
Hi Just empied the basket and now can't get it to run. The light goes on showing it is lined up with the safety switch but still nothing. Put it in reverse and still nothing. Is there another switch I need to find or a sensor maybe stopping the motor from running. All help appreciated. Thanks Frank
  • 1 more comment
  • Izzu Nov 28, 2007
    Mine is the AS1010CD and the issue with is is the "Shredder Misaligned" light is permanently on and the machine has basically stopped working.
  • CSMN Feb 27, 2008
    The red light is on. I think a plastic piece broke off that activates the switch inside so that the machine will run. How do I fix that?
  • 42marcia May 15, 2008
    will go in reverse but not forward. basket is empty and light with 2 little circles comes on
Guys,
Here is an update of the problem:
Using the shredder for continuous extended periods causes the motor to overheat in which case the motor just shuts off automatically.
Leave it for a while to cool down and resume normal usage - this should make it work again.
There is a switch inside the shredder that needs to be activated by a notch in the waste basket. Take extra care to aligh the notch with the slot otherwise the shredder will not work.
No theres the fix!
Posted on Feb 27, 2008
Hi Frank
If it is having the same trouble as my friends (and it sounds like it does, ready light on...no worky)
then I suspect your motor has finally used up it's brushes. I have my friends apart right now and I am trying to find the right brushes. If you know how to order parts or can get me to the manufacturers website or phone number (have not found yet and do not have the manuals) I am on a hunt for the motor brushes (or any that will work.
When I took this one apart the brushes had worn so that they were coming out around the motor rather than pressing against as they should be...and this set is now useless...so need new ones
If you are past warrenty then I suggest taking it apart (dissconnect power first...if it turns on even a little you could be badly injured) and looking at the tail end of the motor (away from the gears
these brushes should be 90 degrees to the motoor and look as though they are just sitting against it in the holder mine were out and on their side against the motor.
If I find the brushes will try and let you know...
it is fairly easy repair
and brushes usually are under $20 for a pair
Matthew Belanger
mtbRESEARCHcor
5084656005
SemperFiPowerSupply
Posted on Sep 13, 2008
I have the same problem "Shredder Misaligned" light is permanently on and the machine has basically stopped working. Help!!! how to fix it.
Posted on Feb 25, 2008
Shredder wont shred
My boss has a shredder that will not run unless the bin is exactly centered in the bottom of the unit. There is a safety switch inside there, and a magnet to activate it. Make sure nothing is interfering with the bin or the shredder fitting together.
On other units, there is a slot that must match up with the shredder. It will only work one way. See of the shredder will turn around and put it on the bin the other way.
Mar 10, 2012 | Aurora Electronics AS1018CD Shredder
The gear is stripped on our AS1018CD shredder. We want to buy a replacement one to install ourselves. Please let us know where we can order it. We did not get any satisfaction with FixYa that you had...
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Jun 13, 2011 | Aurora Electronics AS1018CD Shredder
Does not activate when paper inserted. Runs ok in reverse indicator lights are ok
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. Don't open your shredder to repair it yourself because it will void your warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Mar 05, 2011 | Aurora Electronics AS1018CD Shredder
My AS101bCD Aurora shredder will not shred paper, green light on paper in nothing, will happily go in reverse, what can i do
Sounds like a problem with the switch. Replacement is the most likely option, switches cannot normally be repaired.
Jan 26, 2011 | Aurora Electronics AS1018CD Shredder
Why is it not shredding
Most of the shredders have a protection switch that is cutting the power while the top is removed for emptying the basket. This is a safety feature to prevent from catching your fingers in the knife by accident during the operation.
This switch is located under the top portion and is desactivated by a pin or a bump located on the basket. Make sure to align it properly and you will be able to use your shredder again!!!
good luck
Normand
Jan 09, 2011 | Aurora Electronics AS1018CD Shredder
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Nov 28, 2007 | Office Equipment & Supplies
Aurora Electronics AS1018CD Shredder Logo
838 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
