Question about Janome Sewing Machines
Feed dgs will not return to normal position -Janome decor 5024
Lowered feed dogs to do darning and they will not return to sewing position when switch is activated
robotek
  • 1512 Answers
SOURCE: instruction manual for janome decor excel 2 5024
The learning centre at http://janome.com/index.cfm/Machines/Electronic/DE-PRO_5124 has help for all things from button holes to quilting. Go to the LEARNING CENTER Goodluck. There is a heap of information at this site. Just do a search for what you are trying to do,
Posted on Feb 03, 2008
bargainbox
  • 1388 Answers
SOURCE: Bernina Activa 131: Feed Dogs won't come back up
Raise feeddogs with switch, then turn handwheel one full revolution to re-engage the gear......unless something is jammed, that should do it. Do you have your manual ?
Posted on Nov 30, 2008
SewTechWayne
  • 186 Answers
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
  • 6 Answers
SOURCE: Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
Posted on Oct 21, 2009
  • 68 Answers
SOURCE: The dog feed stuck in the downward position.
When you set the switch for the feed dogs to be in the up position, turn the handwheel 1 complete revolution and they should come up.
Posted on Feb 25, 2010
Now the dog feet won't move back up into position
Hello, Carole -
If you have the owner's manual for your Janome Decor Excel 5018 sewing machine, then you can find the diagram naming the parts of the sewing machine (page 2, English text) and showing part #22, the drop feed lever. This is the lever which controls the feed dog.
If that lever does not move either way, then there may be something jamming the feed dog (like lint) or it may need cleaning and oiling.
If you don't have the manual for your machine, see the image to which I refer here:
https://www.manualslib.com/manual/994905/Janome-Decor-Excel-5018.html?page=8#manual
See this page from the manual to find out how to clean the feed dog:
https://www.manualslib.com/manual/994905/Janome-Decor-Excel-5018.html?page=78#manual
Another possibility for the feed dog not moving is if you have your machine set to the "free-motion" or "darning" operation, which disables the feed dog.
Jan 02, 2018 | Sewing Machines
Where is the feed dog switch on the singer athena 2009 sewing machine
I'm not able to find a reference to a feed dog switch for your machine.
Singer Athena 2000 Instructions Manual Page 9
Could possibly be accomplished using a special plate? The instructions do refer to a darning foot, so the machine should be able to deactivate the feed dogs.
Nov 30, 2017 | Singer Sewing Machines
Janome JF1004 - Lowering the feed dogs
Consult your owner's manual on page 30. Your machine requires an accessory called a "darning plate" that covers the feed dogs.
Janome JF 1004 Instruction Book Page 32
Jan 17, 2016 | Sewing Machines
How to bring sewing foot holder to embroidery position
Hi, I hope this helps. If it doesn't post again.
"Check:
Place the sewing foot under the sewing foot
holder so that the pins of the foot snap into
the sewing foot holder when the presser foot
lifter is lowered.
Please check that the sewing foot is properly
engaged by raising the presser foot lifter
Question: Are you using top feed? If so:
"For all sewing jobs with the top feed, only use sewing feet with Cutout at the back (OA, 1A, 3, 4)."
Embroidery foot Part No.: 98-694-840-00 will not work with top feed.
Also, except for eyelets, the darning foot can be used for embroidery.
I'm not sure what you're trying to do :) darn or embroider :); I'm not sure what mode you're working in either; embroidery mode?
Darning with straight stitch
Program 00
Fit darning foot No. 6.
Set the needle at its highest position by turning
the handwheel, and push the pin of the darning
foot fully into the hole of the sewing foot holder
slightly pressing the darning foot between thumb
and forefinger. When doing this, the guide fork
should place itself around the presser bar and the
wire must be behind the fixing screw.
Darning position:
Lower the presser foot lifter pressing it lightly to
the rear until it snaps into the darning position.
Important Only in this position you have the
optimum thread tension for darning.
• Place the darning work in the darning hoop.
• Lower the feed dog.
• Pull up the bobbin thread and hold the threads
when you start sewing.
• Now guide the fabric back and forth evenly;
the length of the darn will be set by the size of
the hole. As you are determining the stitch
length yourself while sewing with the feed dog
lowered, you should sew at an even speed.
When you have reached the width of the dam
aged area, darn over the damaged area again
from right to left.
This guarantees a durable darn.
TIP: The faster you sew, the easier and more even
the darning will be. It you are moving the workpiece
too slowly, small knots will appear on the
wrong side of the fabric."
Whether working with terry-cloth or woven fabric,
with the help of the darning foot and the pro
gram 02 you can embroider initials of your own
design
Drop the feed dog and insert the darning foot.
Put the machine into the darning position.
Spread the fabric in an embroidery hoop and
embroider in accordance with program 02.
Lower feed dog
If the feed dog is not lowered for embroidering, the
machine does not embroider when the foot pedal
is pressed and the message appea rs:
Lower feed dog
ok?
The feed dog must be lowered in embroidery
mode.
Jun 20, 2015 | PfaFF Creative 7570
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
How do I get my feed dog to move forward on Janome model6019
THE FEED DOG IS IN THE DOWN POSITION FOR DOING FREE ARM SEWING. SLIDE THE PARTS BOX OFF. THERE IS A SMALL SWITCH THAT YOU NEED TO SLIDE TO THE ON POSITION.
Dec 24, 2014 | Janome Sewing Machines
Janome decor excel 5018
if your talking about the feed dogs that they are not up and the fabric is not being feed, then check in your manual to see if you can manually move the feed dogs to the up position so the sewing machine will sew. here is a link for a manual if you don't have one
http://www.sewingpartsonline.com/instruction-manual-janome-decor-excel-5018.aspx
if the information about the feed dogs is not in the manual then you'll have to contact a sewing machine repair shop about having the feed dogs checked to see if there is somthing wrong with them.
Aug 21, 2013 | Sewing Machines
Problem with feed dogs and thread catching
Hello Emma,
Hope this helps.
When the feed dogs are lowered they will not go up with just the switch. Try this, move the feed dog switch to the up position, then turn the handwheel 1 complete rotation. Voila they should be up. Let me know if it is solved. Chris
May 30, 2017 | Janome Sewist 525S Mechanical Sewing...
Mhow do I lower the feed dogs on a Janome 9000 PLEASE
Usually setting the stitch length to 0 (zero) lowers the feed dogs. This was traditionally used for darning.
May 15, 2011 | Janome Memory Craft 5700
Nov 30, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
