Question about Crane Humidifiers
Humidifier beeps and I can't figure out how to stop it
My air innovations keeps on beeping when the reservoir is filled
Hello... this humidifier uses timer? then, some humidity has damaged the circuitry. Try to disassemble as far as your skills permit; then put the unit outside of home in a place where the sun and wind can dry this device. And try to use destiled water if is not expensive in your area.
Aug 10, 2014 | Air Innovations Ultrasonic Digital...
This humidifier has a puddle around the bottom when we wake up in the morning
You are getting condensed moisture from the steam. This could be due to over humidifying. You may have to put something waterproof, such as a big plastic sheet, under the humidifier and mopping up the next day
Jan 15, 2013 | Walgreens Cool Mist Humidifier, 1 ea
We have a kenmore humidifier on the furance model # 48945. it doesn't stop running so our water bill is twice what it should be. I've tried to find a manuel on line so i can figure out how to...
Noodles, it sounds like the float valve inside the water reservoir is stuck in the down position. Turn the water line ON/OFF valve to the humidifier OFF. Open the top of the reservoir and you will see the float valve. Gently, lift it up, to see if it will remain at the top of the water level, which left in the reservoir. It it doesn't, then the float needs to be replaced. In the mean time, leave the water line ON/OFF Valve OFF.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 07, 2011 | Kenmore Humidifiers
The AutoFlo 2000P unit ( 12 years old ) on my furnace is leakng water from the drain spout, which it had never done before. It also is emitting sounds like a low clicking or grinding sound. Where is the...
Tim, they're are generally not hard wired. At least, by today's standards. They're usually plugged into a receptacle. If that's not the case with yours. Open the lid and lift the float valve and tie it some way that can't lower. That will stop water from entering the humidifier tank and it should stop working. Also, look for the water line shutoff valve and turn it OFF. That way, you can be double sure it will stop running.
Hope this helped you to turn it off.
Apr 30, 2011 | AutoFlo 200P Humidifier
Humidifier is not steaming. We replaced the filter but that didn't help.
surprisingly, the salt solution works. i figured it wouldn't make a difference with the ultrasonic model, but i added a bit of salt to the tank, and BAM!
Feb 14, 2011 | Vicks V5100N Humidifier
Water does not stop.
soliniod may be stuck. you will need a volt meter to test
Dec 13, 2008 | Aprilaire 700 Humidifier
Humidifiers Logo
83 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
solver2010
Tom Chichester
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
