Question about DB-DLM-3 Door Lock Module
I need to install the db-dlm-3 Module
I'm installing a Matrix 50.5 Clifford alarm and I'm having problems on how to install the power lock module can you please help me. Thanks
  • Keith Methot
    Keith Methot May 11, 2010
    Whats the problem??
GTI. How can I get my Clifford alarm to operate the central locking?
My best advice is to contact clifford direct and explain your problem normally very helpful.
Mar 02, 2016 | Seat Ibiza Cars & Trucks
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
I need a Clifford 50.7x installation manual
go to www. fitnessmanualsonline.com and download for freeGod bless youcreateLink
Dec 14, 2012 | Clifford Matrix 50.7X - Car Alarm with...
HOW TO INSTALL A CLIFFORD SIO CAR ALARM SYSTEM
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory systems .
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 08, 2012 | Cars & Trucks
I need some help on my old Clifford Alarm system. I purchased my Toyota used about a year ago and I can not get the light on the dash to go off. I replaced the batteries in the key ring on both sets but it...
it is unlikely that the light is causing the battery to drain. it sounds like the system is in valet mode, if it's an older Clifford with a two button keypad somewhere (typically on the dash), turn ignition on, and press the * button twice, then press and hold the blank button.
if it's a newer Clifford system (Clifford Matrix), locate the valet button, then turn the key to ignition (ON), then off and press and release the valet button.
Mar 01, 2011 | Toyota Vehicle Parts & Accessories
Clifford immobiliser unlocks doors, does not start car
Find where your fuel pump relay is and check for power there. Most alarm tech's and alarm system dis engages the fuel pump at there relay's.
Simple things to check is the fuse first then go for the relay and if everything there is working properly, it could be your alarm may have gone bad or your fuel pump it self.
Good luck and hope this helps
Apr 13, 2009 | 1996 Audi A4
Central locking problems
if you unlock the doors via key in drivers door do all the doors unlock . if they do you may have a siezed locking unit
Apr 10, 2009 | 2001 Volkswagen Golf
DB-DLM-3 Door Lock Module Logo
60 people viewed this question
Top Crime Guard Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Crime Guard Vehicle Part and Accessory Expert? Answer questions, earn points and help others
