Question about Master Plumber Plumbing
Need weight of model 504 555 submersible pump
Model # 3976. Pump is basically new, never operated, bought 1997.
boysor2933
  • 293 Answers
SOURCE: pond pump trips safety switch
Check first if there's continuity between the electrical lines and body of the motor. if there is, then you have a line to ground fault in your motor. If there's none, check the resistance between the phase windings. If you get an infinity value, then the motor windings is shorted. If you get an acceptable resistance value, try to rotate the pump with your hand. If there's a considerable resistance, you might have a defective motor or pump bearings.
Posted on Jun 11, 2009
VtToolMan
  • 704 Answers
SOURCE: what kind of is used in a simer submersible
The Simer brand of submersible dewatering pumps rely on being fully submersed in water for proper cooling and for the seals to remain water tight and effective.
According to the manufacturer, there is no oil used in the pump, other than a very small amount that was used in assembling the pump at the factory, so you shouldn't oil the pump, but rather follow the recommendations as to making sure the pump is installed properly.
Here's the owners manual for your particular pump (Model #2300) so you can check the troubleshooting FAQ's and so you can also contact the manufacturer, should you need replacement parts or need to make a warranty claim, etc.
http://www.simerpumps.com/pdf/1000001370.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 17, 2009
  • 523 Answers
SOURCE: I am replacing my well pump/motor and need the
This attachment should answer any questions you may have on the electrical connections
http://www.franklin-electric.com/business/WaterSystems/service/AIM/default.aspx
Tom
Posted on Oct 03, 2009
  • 18 Answers
SOURCE: tsurumi submersible vancs series pond pump has
To get a new owner manual send them an email and they will email or send you one,
info@tsurumiamerica.com
Is the pump was working fine for a long time before that happen?
if yes
There is a motor problem,
You can check your pump power cable try to find any damage or hole in it.
If the cable fine
And if the impeller and wheel still turn before triping the breaker It would be a good thing to check the amperage with a special electronic tool to see how much amperage the pump take,
or
if you are good in manipulating tool we can send you the breakdown or i can support you to open it and to check the motor trying to find any burn part in it. That way we will know right away if its worth to fix it.
let me know
Posted on Nov 11, 2009
Mackmech11
  • 122 Answers
SOURCE: Tsurumi submersible pump with a bad bearing.
Mostly likely no.. These pumps have a sealed bearing that can not be serviced.
Posted on Apr 18, 2010
Any suggestions when a newly installed utilitech pump won't turn off?
its sucking dry or your wiring is not right, or of course an airleak, or the prime is not good, did you fill the pump prime hole at the 3/4 plug on bottom.of pump, deep well pump do you mean submersible? if so and it is a deep well submersible there is a prime, its got to be an airleak in the line or the pressure tank is not pressured up to the specs, and the gauge
May 16, 2015 | Jet Plumbing
I need to adjust the pump. Currently I'm having to go the pump and lift the lever almost straight up where the weight inside it moves and turns on the power. I had a total loser install french drains and...
Replace the float with either a pressure operated float switch, or a verticle float that has a rod in the center, Home Depot has ubiversal floats of all three variations.
Apr 01, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
My waterfall pond pumps keep burning out. The
I found that little giant pump are oiled filled and if it gets hot it frys itself... As for submersible pumps Magnetic drive Beckett Pumps are nice. My Beckett pump has been going for 4 years now it pumps 4800ghp. the cost $269 last I looked.
Oct 14, 2009 | Little Giant Submersible Fountain Pump
What kind of is used in a simer submersible
Sep 17, 2009 | Simer Plumbing
Oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Jul 20, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
I need the instruction manual for a Sears submersible pump model M4D02B-01. I would like to use it to pull water from a lake and about 25 feet in elevation. It is rated at 230 volts but I currently only...
Assuming that your Sears submersible pump Model
M4DO2B-01 can pump water at more than 25 feet
elevation. You can run it even without a manual. Just connect your discharge hose up to the point of discharge. Use a 220/110 volts transformer with a rating of at least 3KVA. Connect your 110 volt line to 110 outlet of the transformer and the submersible pump to 220 outlet of the transformer. This 3KVA transformer can handle up to 1HP pump.Send your
e-mail for further assistance.
Jul 07, 2009 | Plumbing
I have a jacuzzi 1/2 hp submersible well pump. Does this need any regular maintainance to keep it happy.
No preventative maintenance is necessary. However, a happy pump always has water above it and should not pump sand. If the water level in the well is below the pump/motor they will overheat. If this is a problem your local pump company can install a module to protect your pump from this type of event.
Please rate this answer.
Jul 03, 2009 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
Switching off too soon.
you don't need to replace the switch just raise the upper stop up higher so the float can go higher before turning the pump on, it should have a rubber gromet on it slide it up the rail
Jun 21, 2009 | Flotec 3.4 Hp Floodmate Submersible Sump...
Replacing float switch on water ace r3s pump
I have been in this business for a ong time 34 years by the time ou take the pump apart and find the right peices it would be cheaper to buy a new pump, suggest zoeller submersable pump,,
Mar 17, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Plumbing Logo
Top Master Plumber Plumbing Experts
Donni Steen
Tom Chichester
Are you a Master Plumber Plumbing Expert? Answer questions, earn points and help others
