Question about Whirlpool GZ25FSRXYY
Left Door will not stay open
Can't get the left door stay open. is this a design flaw? or can i make an adjustment to the hinge?
ghappliances
  • 126 Answers
SOURCE: refrigerator section is not cooling
HELLO AND THANK YOU FOR THE QUESTION.WHEN ONE LEAVES THE FREEZER DOOR OPEN FOR A LONG PERIOD OF TIME ITS BEST THAT THE UNIT BE SWITCHED OFF AND THE ICE THAT HAS BUILT UP DEFROSTED BY ITS SELF BEFORE SWITCHING THE APPLIANCE BACK ON TRY THAT AND LET ME NO IF THAT SOLVES YOUR PROBLEM.GOOLUCK. MOHAMED
Posted on Sep 15, 2008
ghappliances
  • 126 Answers
SOURCE: left freezer door open ice
THE PROBLEM MIGHT BE WITH YOU ICE DISPENSER MOTOR.TRY TAKING THE ICE DRAW OUT.CLOSE THE DOOR AND PUSH THE ICE FLAP IN THE FRONT OF THE DOOR.IF YOU DONOT HEAR A LOAD NOISE THATS A INDICATION THAT THE MOTOR IS NOT WORKINK.LET ME NO IF YOU REQUIRE FUTHER ASSISTANCE.GOODLUCK.MOHAMED
Posted on Sep 18, 2008
  • 1462 Answers
SOURCE: freezer door needs to be raised
just put some washers (plastic washers are best) on the hinge pin to raise the door
Posted on Nov 16, 2008
sdmc73
  • 121 Answers
SOURCE: French door on right keeps swinging open
yhe leveling of the unit will help
Posted on Nov 29, 2008
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
Maytag fridge right door won't stay closed
it may be necessary to reset the hinge adjustment to move the door further across the opening giving the magnets a better area to hold on to . there is a slight amount of adjustment in the mounting points of the hinges. You may have to replace the door gaskets as they become hard over time and the magnets cannot work properly in the hard plastic
Jun 21, 2013 | Refrigerators
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
The lower hinge on each door may have a door closing cam. It raises the door up ΒΌ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
May 04, 2011 | Refrigerators
Door won't stay shut
To adjust the door on a refrigerator, you need to make an adjustment at the hinge to the door. Don't know what you have, but all refrigerators today cann be adjusted at that hinge to make it bias toward swinging open or shut when left alone.
Tom
Mar 20, 2011 | Refrigerators
When I open the drivers side door the hinge pops
oil hinges.check that door & front fender aren't rubbing.
Sep 23, 2009 | 2002 Saturn SC
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Freezer door opens just a tiny bit when i shut the fridge side anybody know how to fix this
to be honest with you, close the door more gently. there are air vents between the frig and the freezer, when you close the frig door its forcing air into the freezer which in turn forces the door open some. the air has to get out so thats what it does. i hear this complaint alot.
Nov 27, 2007 | Frigidaire FRS3R5EMB Side by Side...
Maytag Fridge French Door hinge discrepancy - hard swing
Vhotho, Maytag put out a service bullitin regarding this problem. This of course is for the model that is posted. The fix is to install a new right side center hinge and door stop limiting the opening to 135 degrees. They must of redesigned it. I can give you the part numbers. Black and stainless the hinge is 67006443 and the stop is 67006276. For white the hinge is 67006379 and the stop is 67006278. This bullitin came out in Feb of 2006. TDR-0057a-b. Catriver..post back.
Jan 04, 2007 | Maytag MFD2561HE Bottom Freezer French...
Whirlpool GZ25FSRXYY Logo
16 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
