Question about Technics SL-1210 Turntable
Pop up light is off all the time
My friends pop up light has never worked since he bought the turntable.
Can you please help me find out how to replace or repair the light,
Any help gratefully recieved
All the best,
Steve.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
Probably as in most cases the connector on the bottemside of the light came loose,this is mostly caused by moving them in cars,otherwise the lamp itself id broken.i hope this is of any help to you
Posted on Jan 30, 2009
Technics SL-220 not turning (although it seems to be trying!)
I'd suggest to unplug it from power for 5 minutes push a couple of times on power button (while unplugged) then plug it back.
Jul 10, 2015 | Technics Audio Players & Recorders
Less than 5 years old - Microwave Panel lights up, turntable turns, fan works - everything works except it doesn't heat food. Heard a pop, and now it runs louder than before but doesn't heat. Any ideas?
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Dec 02, 2010 | Frigidaire PLMV169DC Microwave Oven
Pitch problems
You would need to calibrate them to each other. Not very difficult, but not that easy either.
I would suggest taking it to a service center, and ask them to calibrate the turntables to each other. It's a matter of adjusting VR302, which is located underneath the turntable platter. You'll also need a frequency counter or similar - which aren't cheap.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 15, 2009 | Technics SL-1210M5G Turntable
Teac GF-650
hi, please if you can open the turntable unit ,go on the part of power supply please double check the fuse first...maybe that is the solution for your problem...find the supply section ... you can find it from the AC plug going to the deck end..u
Jun 25, 2008 | Teac GF-650 Turntable
Technics 1210 pop up light?
Maybe you should try putting a smaller (in Watts) lamp in the pop light...
Nov 09, 2007 | Technics SL-1200MK2 Turntable
Technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Oct 19, 2007 | Technics SL-1200MK2 Turntable
Pitch adjustment light is always on
Ok DJ,I use to Dj too,Probley you have moved the equipment quite a Few times,Is the Table Synchronous if so you might have some dust in you control throwing it off,Also Different locations have ac Voltage differences,Ck that too... Other wise go to radio shack and pick up some Contact cleaner Good luck let me Know ttech
Jul 24, 2007 | Technics SL-1200MK2 Turntable
Turntable problem 80802
It looks like the mechanism on those models consists of a glass tray a roller ring, and a motor, but in the diagram I don't see a coupler... The coupler may be built in to the motor or tray. You can visit http://www3.sears.com/ and enter your exact model number - like 721.80802### - not just 80802. The parts lists and exploded view diagrams for the turntable parts should be located in the section "Interior Parts 1". Those will help you figure out what part(s) you need, which you can order online or by phone or in any Sears store. If you need more help, repost with any new details you have. I appreciate your rating of this reply.
Nov 13, 2006 | Kenmore 80809 Microwave Oven
Technics SL-1210 Turntable Logo
79 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
