Question about Akai LCT3201AD 32 in. LCD Television
SAP I get an SAP(Simultaneaous Audio Program, I assume) message at the top of the screen. I can find no way, in the menu, to shut off the SAP. It is causing audio problems and it is almost impossible to listen to the normal sound. Any sugestion are greatly appreciated.
  • Ken Hunt Jul 08, 2007
    I found a button on the remote that is labeled MPS which changes the color of the "MONO SAP" alternately-Mono(yellow)SAP(red) vs. The model of the TV is LCT3285TA.
Problem with sound after 30 min when in TV mode
Posted on Apr 29, 2008
    Scholar:
  • 150 Answers
There might be a SAP button on the remote or under a cover on the remote, or it might be an audio button, you want Main or Stereo. I couldnt pull up a picture of the remote, but I would suspect that if the SAP function is not in the menu it is probably on the remote.
Posted on Jul 08, 2007
  • les lake Jul 18, 2007
    if program is not stereo, the mono option is what you want
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
I would like to remove the voice over settings on my TV but unsure how please can you help? The make of the TV is Technika. Thank You
You probably have the second audio program (SAP) turned on. Return to the initial set up procedure and disable SAP.
Dec 26, 2014 | Televison & Video
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
How do you remove text from your tv screen
I am assuming it is the closed captioning that is showing... should be a menu item to turn of CC ('Closed Caption') or SAP (Second Audio Program tends to be bilingual and not CC).
Peace,
Mar 07, 2010 | Toshiba MD20F51 20 in. TV/DVD Combo
How do i program cable channel in to my 27" tv ,,only has local channels 2-13 when we use auto program, no other stations lock in to the tv....SAP in left hand corner 27" glass screen flat
You have to make sure the TV is set to cable not air. Will not look for upper programs unless it is set to cable. SAP needs to be off in the setup menu unless you want it on. Secondary Audio Program(SAP) is for foreign languages.
Sep 23, 2009 | Televison & Video
My tv is on spanish how do i take it off
Spanish on the screen or Spanish through the speakers on some channels? If its the on-screen display that's in Spanish, you pick the language using the setup menu with the remote control. If you're getting Spanish through the speakers, you probably have turned on the SAP (second audio program) function. In some areas with a large enough population, SAP is often used to broadcast program audio in a different language. On channels with no SAP broadcast you don't hear any problems. The SAP function is usually controlled by a button on the remote and probably got pressed by accident.
Dec 01, 2008 | Hitachi 51F500 51" Rear Projection...
Sharp Liquid Crystal TV - Flat Screen - 1.5 years old
Go into the menu and under AUDIO and make sure that the sound is set to STEREO, and not SAP (second audio program). If you have a separate setting for SAP then shut it off.
Apr 23, 2008 | Televison & Video
Akai LCT3201AD 32 in. LCD Television Logo
414 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
