Question about Hitachi RAS-09UH Air Conditioner
I transfered my hitachi AC split type model RAS25RC to my new house but when the technician re-intalled the unit, the fan inside working but the compressor and fan outside was not working. what seems to be the problem?
5 Suggested Answers
  • 3 Answers
SOURCE: The fan in the outdoor unit does not work while the AC is on.
these motors are famous for the inyernal fuse blowing in the fan motor. check continuity between the red and blac wires. if there is non the fuse is gone. These motors are fairly easy to take apart and change the fuse . hope this helps
Posted on Sep 01, 2008
  • 5 Answers
SOURCE: Hitachi model number unknown !! (faded 0ff unit)
dirty unit and need for cleaning
clogged up expansion valve
defective fan motor
deffective air sensor
Posted on Jan 26, 2009
SOURCE: My AC unit ouside the house works,but the fan
check the breakers first they are probly on seperate breakers if thats not the problem your fam motor may have over heated and need to be reset or replaced after being tested
Posted on Jul 12, 2009
  • 10 Answers
SOURCE: periodic noise on outside unit after being charged with gas
maybe. he should check for superheat and sub cooling with digital stats and calculate those number in relation to the outside temp. if he just put the hoses with the two gauges on its really really hard to adjust properly. a couple oz. of gas really can make a diff in the numbers not detectable by the hose and gauges and can make your system freeze up of not work at all.
Posted on Nov 21, 2009
I HAVE 1.5 TON SPLIT A/C WHAT SIZE OF RUNNING CAPACITOR WILL WORK IN COMPRESSOR?
the capacitor that is required is the same size as what is fitted
it will read as voltage and uf number
best have a ac technician check it out as it may not be the capacitor but the power board
some ac units have a capacitor that is in effect two capacitors in one to run the compressor and the cooling fan as well
best get the technician in as it could save a lot of money in the long run
Aug 08, 2015 | Dayton Permanent Split Capacitor Motor Fan
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Compressor fails to restart
indicates that the compressor is not communicating with the program board in the inside unit
could be a relay problem
call in the service technicians for a proper diaganosis
Sep 12, 2017 | Honeywell Heating & Cooling
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
It is very loud inside when turned on. the noise sounds like a loud rumbleling noise.
Is this a window unit, a whole house AC, or a Split package type?
If it is a window unit remove the front cover, reach in and see if the blower fan teeters on the mother shaft. If it does the blower fan center hub has failed and the fan will need replaced. (I have changed 2 blower fans on my Carrier 19,800BTU window units that run 23 hours a day.) They just fail over time. Who knows why.
Kelly
Feb 23, 2010 | Heating & Cooling
My AC unit ouside the house works,but the fan inside the house does not work. It does not come on any more, not even when I change the fan setting from Auto to On.
Jul 12, 2009 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS 5142CHA Won't operate
Check the fuse on the control board inside the head unit,if its ok you need to replace the contrl board
Apr 04, 2009 | Hitachi RAS-09UH Air Conditioner
defective fan motor
May 22, 2008 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS-09UH Air Conditioner Logo
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
