Question about Hoover U6476-910 WindTunnel Upright Vacuum Cleaner Bagged Vacuum
Hoover windtunnel red light stays on - Hoover U6476-910 WindTunnel Upright Vacuum Cleaner Bagged Vacuum
2 Suggested Answers
SOURCE: hoover windtunnel dirt finder light stays red
I'm not sure about a 3 month old vac, I'd probably go the warranty route. However, for the older vacs thy start getting false positives. The sensor is simply a microphone hooked to a computer chip detecting sounds of dirt entering the bag.
To rig it to start working, you'll need to remove the tool accessory tray and elbow that enters the back of the vac, and attached to the bag. This will reveal the microphone at the elbow, and wire that runs into the bottom area of the vac. When on, a large amount of air comes from the bottom screw and area where the wires enter. My fix was to clean up the microphone contact points a little bit with a screwdriver, and then leave the vac running while putting in dampering in the hole at the bottom, and around the back of the elbow. Cotton balls and electrical tape at the bottom hole, and napkins around the outside of the elbow (wedged between the back of the vac assembly and elbow did the trick). The schematic for the vac is here: http<colon>//www<dot>vacsrus<dot>com/CartGenie/pg_U6485900<dot>asp
Look for micrphone.
Posted on Jun 27, 2010
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Embedded light sensor stays red all the time
The back cover is called the a micro/dust assembly. See #21 here:
http://www.ereplacementparts.com/hoover-u6630900-windtunnel-selfpropelled-bagless-vacuum-parts-c-37315_37337_37584.html
The little sensor should be in the round recess in the top of that assembly. When you are putting the cover back on you have to use a pair of needle nose pliers to push the sensor into the round recess until it is snug. It is hard to do because the wires to the sensor are very short and you have to be careful not to break the wires on the sensor. The sensor is a little microphone that senses the noise of the dirt going through the EDF. The first time I did mine I didn't push it in hard enough and came out of the EDF recess and fell inside the vacuum body.
Jun 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover windtunnel dirt finder light stays red. We've cleaned the elbow the roller the hose and have a clean bag. The vacuum is new only had it for 3 months.
Look for micrphone.
May 12, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
My Hoover Dirt Finder red light stays on. All
Inspection of the circuit board found that the 470uF capacitor looked damaged. I replaced it and I now have the Green and Red lights are working correctly.
Jan 19, 2010 | Hoover U6476-910 WindTunnel Upright Vacuum...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Red light stays on
It sounds like the plates inside the vacuum that detect the dirt have become dirty. I don't remember where they are, but I think they're accessible if you remove a certain hose. Again, I don't know which hose it is.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Redlight stays on on hoover self propelled windtunnel selfpropelled does not work
red light is gimmick and you most likley broke your transmission acuator arm
Aug 08, 2008 | Hoover Vacuums
Dirt finder
The sensor may be bad, or it may be coated over with dirt. Re,ove the hose at the back of the vacuum, the head of the sensor is down inside that opening, reach in there and clean it off and see it that corrects the problem, if not replace the sensor.
Oct 16, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Embeded Dirt Finder
check out the switch that activates it. go to thehooverstore for a complete listing of hoover machines. I'm sure you'll find your machine listed along with an exploded diagram of the machine
Sep 19, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6476-910 WindTunnel Upright Vacuum Cleaner Bagged Vacuum Logo
47 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
