Question about Acme 5001 Supreme Juicerator Juice Extractor
Acme Juicer My Acme Juicer has begun to make a mild screech from the motor. Is this repairable somewhere or is it going to be less expensive to just buy a new one? I can't find the company home page and don't know where to send it. Thanks for any help!
    Champion:
  • 356 Answers
WARING HANDLES THEM AT 800 492 7464.
HOW OLD IS IT? BEARINGS COULD BE GONE.
THEY ARE REPLACEABLE.
Posted on Jun 30, 2009
Also had thsi problem its our counter. i used it in a differrent surface no noise or slide. try that.
Posted on Feb 16, 2012
  • margaux Ceo
    margaux Ceo Feb 16, 2012
    also had thsi problem its our counter. i used it in a differrent surface no noise or slide. try that.
SOURCE:
Need a manual for acme juicer 6001, juicer at least 30 years old
The juicer hasn't really changed over time, but you
need to be a little mechanically inclined to adjust
and keep it running properly. Call Waring at tel
1 800 492 7464. Good luck. Mine is 21 years
old and running like new.
Jul 30, 2010 | Acme 5001 Supreme Juicerator Juice...
Stuffed parsley into the juicer and the motor stopped
Push red reset button on bottom of juicer. The
juicer is not designed for leafy produce, only
apples, carrots, celery, etc.
Apr 22, 2010 | Acme 6001 Juice Extractor
Acme juicer vibrating so much.
I've had one for 21 years and when I replaced the blade the same thing happened.
The blade is not supposed to be held firmly in place so it can slip intentionally to
minimize vibration. If you bought the juicer new, think back, and I believe you will
remember the vibration problem. I seems with a worn blade they vibrate less. The
motor is very durable and uses roller bearings like on a skate board. I went back
to the old blade, which I sharpen with a drill using a small bit.
Jan 11, 2010 | Acme 6001 Juice Extractor
Why does my supreme juicerator shake and make noices
the rubber banding on the bottom of the shredder disk gets worn over time and you might need to buy a new shredder disk. I was experiencing the same problem (the juicer was vibrating at an odd speed,shaking and the sound of the motor was distressed, when the plunger was inserted to push down the veggies it was banging and making an awful noise) replacing the disk solved the problem - good as new.
Sep 28, 2009 | Acme 5001 Supreme Juicerator Juice...
The 6001 vabrated so much the top came off and the flang bent.
WARING AT 800 492 7464 HANDLES ACME
JUICERS. VIBRATION MAY NOT INDICATE
REPAIR. THIS JUICER DOES NOT EJECT
PULP SO IS PRONE TO VIBRATION JUST
LIKE AN INCORRECTLY LOADED WASHING
MACHINE. HOWEVER, SEVERE VIBRATION
WILL CAUSE THE BLADE TO CHEW UP THE
CHUTE. YOU WILL NEED A NEW COVER.
TALK TO WARING. ANOTHER PROBLEM
IS NEW COVER PROVIDED WILL NOT FIT
SOME OLDER JUICERS WITHOUT FILING
DOWN THE EDGE OF THE COVER. TAKES
TIME BUT CAN BE DONE.
Jun 24, 2009 | Acme 5001 Supreme Juicerator Juice...
Acme 6001 juicer. Excessive vibration and movement during use.
usually the vibrations are caused by improper assembly ( it does not take much ) or the rate of feeding material into juicer. feed the juicer too fast and it gets out of balance.
Jan 04, 2009 | Acme 5001 Supreme Juicerator Juice...
Excessive vibration and movement of  acme 6001 juicer during use. Tried different products, using less, not helpful.
test by running empty for several minutes,, should be smooth running. then feed the juicer slowly. I have not seen a problem with what I feed in, solid or pulpy material not leafy material.
Acme Juicer Supreme Juicerator 6001
BEARINGS MIGHT BE GONE. OLD JUICER
AND SOME PARTS ARE NOT AVLB. OR
HARD TO GET. THEN AGAIN IT MIGHT BE
SOMETHING SIMPLE. MINE IS FROM 1990
AND I DO MY OWN REPAIR. NOT WORTH IT
TO PAY FOR IT.
Mar 21, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme 5001 Supreme Juicerator Juice Extractor Logo
192 people viewed this question
Top Acme Juicers Experts
hawk630
Level 1 Expert
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
