Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
How to switch off answering machine
I don't want to switch on answering machine, but it automatically switches on itself, if the call is not attended (even without leaving a message)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Nov 30, 2012
  • kakima Nov 30, 2012
SOURCE: Answering Machine not recording!
The reason the answering machine doesn't work is because it is not DSL compatible! If you have DSL internet for your computer, the phone lines are not compatible with the answering machine!
Posted on Mar 31, 2008
SOURCE: Reset the answering machine without the manual
GE 28112EE2 1.9 GHz Twin Cordless Phone
Flashing CL.
Lost Manual.
Can you help.
Posted on Jun 23, 2008
SOURCE: answering machine
Please tell me how to program my answering machine so a message can be left on our machine.
Posted on Jul 12, 2008
SOURCE: radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Recording Outgoing Messages:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
Posted on Nov 20, 2008
  • 6 Answers
SOURCE: Power failure message.
Power Failure Recovery
If the system is disconnected from the AC power it will not operate. Your announcemen and messages are retained in memory during a power failure but you will need to reset the clock. See the instructions on the bottom of the unit. If the message window displays CL, you need to reset the clock. See the instruction on the bottom of the unit.
Posted on Feb 25, 2009
Trouble shooting
You're in the Announce mode, where the machine plays an announcement but does not record a message. It switches to this mode automatically when memory is full. If the memory is not full, you can switch between the Announce and Answer modes by pressing the [ANSWER ON/OFF] button. You're in the Answer mode when the button lights up red.
Dec 10, 2011 | Sony TAM-100 Digital Answering Machine
What is the fuse number for the windows on a 1996 Ford Mustang
Hi, download your manual here: https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
On page 282, it says the power windows are on a 20 amp circuit breaker. This breaker automatically resets itself, so I doubt it is your problem. I don't have the wiring diagram, but if the driver's switch panel has a safety shutoff, then all power goes thru that switch. If the power is not getting there or the switch is bad, then none of the windows will work.
Jun 04, 2011 | Ford GT Cars & Trucks
Machine will not work. I checked the power source and also the cord is plugged into the machine and power source and still nothing
I don't fully understand what you mean but I assume the machine does not come on?
Some fax machines have a power switch, others don't.
Did you check for a power switch on the machine itself? Might have got turned off by accident.
If the fax suddenly quit, I'm afraid the problem is with the power circuit inside the fax machine.
You may need to take it to a service depot.
May 31, 2011 | Samsung SF-560 Plain Paper Laser Fax
GE Profile washer shows d5 how do I eliminate that so I can wash
Hi and welcome to FixYa, I am Kelly.
D5 is a lid switch error. It comes on when there are 3 complete cycles without a lid switch actuation. Either the lid switch has failed or something is causing the lid switch to not sense lid movement. This is a proximity type switch that uses a magnet to actuate the switch. Check to see that both the switch is in place and that the lid itself is not loose at the hinge or shifted to one side.
The lid switch is item 90 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130746
http://www.appliancepartspros.com/part_details.aspx?part_id=3204102
You can try to unplug it for 6 minutes and plug it back in again to clear the code but if the lid switch is bad you will get the D5 code again. Not only that if you have children around it is not safe to leave the washer un-attended with a bad switch because the machine will not stop spinning in the spin cycle with a bad switch. If they lift the lid and stick their hands inside the end result can be quite horrific.
Thanks for choosing FixYa,
Kelly
Mar 27, 2011 | GE WHRE5550K Top Load Washer
Hi, I have a Cordles phone Uniden 6.0 Model: DECT1588-ST. Problem: The call gets automatically attended, after 6 rings at the max. Since the Number of Rings can be set to a maximum of only 6...
Hi
owners manual page 46 how to turn answer on/off
https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/DECT1588om.pdf
Sep 07, 2017 | Uniden CEZAI998 Phone
The model of my AT&T answering machine is 1720...it is linked to a Brother's fax machine...when a call comes in I am not able to pick up the phone and interrupt the message from the answering machine...
Connect the telephone line of the answering machine from the series connection of the facts machine
.Now set the number of rings for the answering machine to activate to the maximum.{This is found on the side of the machine as a reed switch.}
Now when the calls comes in there is enough time for you to allow it to the answering machine or to attend a call or to set it to facts if a document is comming.While you are away you have to decide the priority needed for either facts or answering as it is a commonline. If answering machine has to work set the facts to telephone mode.If facts has to work set it to facts as the machine will activate before the answering machine.
Sep 02, 2010 | AT&T Lands Phones
Sharp Aquos 46in LCD AV Mode switching to Dynamic(fixed) by itsel
Sorry I´cant help you, but I´ve got exact the same problem.
I´m from germany. I searched the german web, but nothing.
Did you have an answer right now?
Apr 03, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
How can I switch the auto attendant service off so I can answer the phone before it goes to auto attendant?? I have a nortel T7316E. I was cleaning the phone and somehow turn on the auto attendant, but can...
Somewhere on your set theres probably a night key that was accidently pressed. It might or might not be marked as such,but there should be an indicator (triangle) on the screen that shows that its on. TO turn off press the night key again. The indicator should go off.
Jan 04, 2010 | NorStar T7316E Corded Phone
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
Number of rings before answering system goes on
You can adjust the Answer Delay time by going to Menu then DTAD. Adjust the Answer Delay under this menu... 6 seconds per one ring.
If you have auto attendant set up to answer for you in a multiline system, set that delay accordingly. That will be the first system to pick up, You should set up one auto attendant for every voice line coming into your phones.
Dec 18, 2007 | Lands Phones
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
23 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
