Question about Waterway Pool & Spa
Leaking Waterway pump - Waterway Pool & Spa
    Top Expert:
  • Waterway Master
  • 8,163 Answers
Replace pump
Posted on May 01, 2016
Remove impeller from Waterway 502n22c
To remove the impeller you first take the front face plate off to expose the impeller. Then isolate the shaft from the motor with a pair of needle nose vise grips and using a pair of channel lock pliers grip the end of the impeller and rotate counter clockwise to un thread it from the shaft. If the shaft seal has been leaking there may be to much corrosion to turn the impeller in which case it needs to be broken off.
May 13, 2013 | Waterway 5HP Executive 56 Frame Spa Pump...
Need to change seal on pf-40 waterway pump
can change but water leaking into motor it will start to squeal bad bearing just change whole pump
Dec 26, 2012 | Waterway 5HP Executive 56 Frame Spa Pump...
Shutoff valves leak
The valves need tightening quite a bit. Take them off and wrap the PINK 1/2" teflon tape (Home Depot, Lowes) around them 3 to 4 times. Then take large wrenches, one to hold and one to tighten, and tighten them quite tight. If they still leak, turn off and tighten more. Eventually they will seal and stop leaking. Also, make sure, if they use them, that your O-rings are properly positioned.
May 28, 2009 | Waterway Above Ground Hi Flo Pump
REASSEMBLED WET END OF WATERWAY PF401A22C-LEAKS- NEED DIAGRAM
I've never seen a reassembly diagram for this particular pump but I'm guessing that you've installed the mechanical seal incorrectly.
Where is it leaking from exactly?
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Apr 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Pool & Spa Logo
19 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Mike
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
