Question about Bosch Water Heaters
Water Leak in Bosch Highflow water heater
I'm in Whangarei, NZ, and have an old model YS2431R Highflow gas water heater - approx 12 years old. Water inflow has sprung leak (can see water dripping from the inflow pipe & bottow of unit).The water is shorting electrics, tripping saftey switch on the power board. No hot water as a result. Bosch NZ extremely unhelpful - automated phone system doesn't transfer to a service agent, but to some poor woman in another part of the country who's phone number has been wrongly included on the automated list. When I finally got hold of a live person at Bosch (after 4 attempts), I was told it wasn't their problem to fix!
  • 2976 Answers
SOURCE: Slow leak drips from bottom of 4 year old model
You can probably repair this by removing the fittings and replacing any plastic compression rings with new ones. Everything else can be cleaned with grade "0000" steel wool. This will get rid of any deposits without damaging the surfaces. ! or @ careful wraps of Teflon Tape to the MALE threads will help get a good seal.
Posted on Feb 04, 2009
  • 234 Answers
SOURCE: I have a bosch YS2433R 'Highflow' hot water
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1696702
Posted on Mar 19, 2009
mrhotandcold
  • 248 Answers
SOURCE: No hot water
diaohragm valve or micro switch
Posted on Oct 12, 2009
SOURCE: Bosch 2400E-NG output temp fluctuates
Tankless heaters do not like back pressure from anti scalding devices in shower controls. Every time they compensate and shove more coldwater to the hot side so you don't get burned when someon is using the cold water elsewhere in the home, it can reduce the heater below it's minimum flow rate and shut it down. Nothing wrong with the heater. Ask kohler if there is a wy to disable the device without buying a new unit entirely.
Posted on Jul 26, 2010
SOURCE: RHEEM 40 GAL ELEC TALL Water Heater 6YR SC 82VH402: my rheem 81sv40d water heater quit heating water. ...
I have the same problem about every 3-4 months. Mine is also about 10 or 11. It is usually the sediment at the bottom that causes this. Once the plumber flushes it, it works again. My problem is that I dont know how he did it and the vavle is at the floor level. I am never home when it is repaired. Regular maintenance (flushing) is how you avoid this from reoccurring. That is, if that is the cause of your issue.
Posted on Feb 04, 2011
Bosch 125fx heater barely heats water
1) Recommend replacing tankless with ordinary tank-type gas water heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://hometips.me/Mar/Which-is-best-gas-water-heater.pdf
2) Tankless cannot be exposed to more than 11 grains hardness in water or unit will fail within 2-5 years. Water softener is required.
http://hometips.me/Tls/Battelle_Water-softening-research.pdf
3) Descaling tankless water heater each year will not restore functionality, or restore efficiency of tankless, nor restore full efficiency to tank-type gas water heater.
4) Bradford White side-by-side testing research comparing their tankless with their tank-type shows that tankless will save $1-8 per month on energy bill vrs ordianry tank-type ....but conclude that tankless 'fall far short of payback' due to maintenance, repair, installation and replacement costs.
Study compared full cost, and not just monthly energy bill, since All costs are energy.
Feb 16, 2013 | Water Heaters
Bosch aq 125 no water preasure
Clean water filter yearly or monthly. Page 16 example manual.
http://waterheatertimer.org/pdf/Bosch-125BO-NG-LP-outdoor.pdf
Shut off the installer supplied cold water supply valve.
Disconnect water pipe going to the back of the water
valve. Remove filter from back of water valve. Clean the
filter and inspect for damage. Replace if the filter is at all
damaged. Inspect the top of the water valve for signs of
a water leak or corrosion. If present, rebuild the water
valve.
Bosch service bulletins:
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/38b-125-series-bulletins.html
Descale heat exchanger yearly.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Sep 29, 2012 | Bosch Water Heaters AquaStar 125 series...
My Boch 24ES Highflow Hotwater is showing Code 14 and only runs for i minute then shuts off
Code 14.
What water heater do you have?
Question posted under tankless Bosch, but these error codes start with a letter.
Rheem/Richmond etc Tankless has error code 14
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Call tankless service technician.
Ask technician how much it costs to have recommended yearly service.
Or install whole new tank-type gas water heater yourself for $350 from local box store, and avoid the entire headache, then sell tankless online for parts.
Aug 09, 2012 | Water Heaters
I have a Bosch 10P water heater. Pilot light has blown out and while trying to relight the pilot the stop button has been pushed down and won't pop back out. What am i doing wrong? Cheers
What leads you to suspect that pilot blew out instead of another problem?
Fact that pilot will not relight, indicates other factors at play.
Open following link for Bosch troubleshooting resources including manual, and Bosch contact info:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Best place to start is your manual.
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
1) Manual recommends 'cleaning by authorized person, never less than once a year.'
Tankless water heaters, and most newer tank-type gas water heaters, are highly technical and finicky devices that require continual maintenance, with tankless requiring 'yearly' maintenance while tank-type require 'periodic' maintenance.
2) Troubleshoot in manual says 'no gas supply' or 'blocked pilot' replace pilot injector
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Bosch & Tankless LP Hot Water Heater
Hi my Bosch 18 e highflow instantaneous hot water service, turns water cold after a minute or so then stays cold. When you turn the water off the pressure valve keeps pulsating for about 5 seconds. The...
Open following link for Bosch troubleshooting resources, including contact phone numbers and possible manuals.
If the conversion was made 3 years ago without a problem since, it might not be a factor.
May 05, 2011 | Water Heaters
Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
May 13, 2010 | Bosch Water Heaters
Had the unit for seven years, it started to leak water around the water valve. Bosch aqua Star 125x ng
You have to fix this leak around the water valve before
it causes damage to your equipment.
1. Close the water supply valve going to your tankless
water heater.
2. Unplug or close the natural gas valve.
3. Now, you can work fixing the leak.
4. Once completed, you can proceed to open the
natural gas valve as well as the water supply valve.
5. Then, have it tested to get it done.
5.
Nov 27, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
No hot water
Nov 14, 2008 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
32 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
