Question about Black & Decker JE 1500 Juice Extractor
I have a problem removing the cutter/strainer
I cannot remove the cutter/strainer from the machine. It rotates, but I cannot remove it for cleaning.
0 characters
1 Points
Problems dismantling champion juicer
It's like a suction is created. I have had this happen. I managed to get mine off with a blunt knife to give a bit of leverage (not ideal I know to put a knife near an expensive piece of equipment but it worked for me) Once you have the blade cutter off I suggest oiling the metal prong that it sits on with something like vegetable oil or olive fairly regularly to avoid this happening again.
Feb 23, 2014 | Champion Juicers
I need to remove the parts for washing How I do this?
Things You'll Need:
  • Soft-bristled brush
  • Stiff-bristled brush
  • Dishwasher (optional)
  • Mild detergent
  • Lint-free microfiber cloths
  1. Unplug your Acme 6001 Juicer. Carry it to a countertop near your kitchen sink.
  2. Remove the pusher and cover, and set the pieces in a sink. Unscrew the clutch, remove it and set it in the sink. Remove the cutter blade, strainer basket and juice bowl, and place the pieces in the sink.
  3. Discard or remove and store any pulp that you find in the strainer basket. When you're finished, rinse the remaining fruit and vegetable pulp and juice from the pieces under cool, running water. Dislodge hard-to-remove pulp from the cutter blade and strainer basket with a soft-bristled brush or with a stiff-bristled brush if necessary.
  4. Wash the pieces in a dishwasher or by hand. To wash in a dishwasher, place the stainless steel pieces in the lower rack and the plastic in the top rack and wash on a normal cycle with other kitchenware. To wash by hand, fill the sink with warm water and a few drops of mild detergent and wash with a lint-free microfiber cloth.
  5. Run the pieces through the rinse cycle in your dishwasher or rinse under running tap water by hand. Air or wipe dry the pieces.
  6. Wipe the base with a slightly soapy cloth. Rinse with a damp cloth and wipe dry. Reassemble your juicer by returning the pieces to the base in reverse order.
     for a visual:
Jan 28, 2011 | Acme 6001 Juice Extractor
Juice extractor 67800 350 Watts, The problem is the cutter strainer gets stuck and I can only get it off after much effort and struggle, is there a simpler way ,Margaret
As soon as I had described the problem I found the solution. A smear of olive oil around the inside of the base of the cutter, and around the seating of it, on the unit. And it worked. No problem.
Nov 04, 2009 | Hamilton Beach 67800 HealthSmart Juice...
Cutter is stuck onto shaft, how can I remove it?
First, check to see if there is a set screw in the side of the cutter which screws against the shaft.
If no set screw, a gear puller would probably do the trick. There are many types -- you might luck out and find one which will fit on your first shopping trip.
Apr 29, 2009 | Champion 2000+ Household Juice Extractor
Jack lalanne juicer, 8 yrs.old model?
I have a Jack LaLanne power juicer model number JLS-8 and lost instruction manual and don't remember how to remove filter basket to clean machine.
Sep 08, 2008 | Juicers
Cleaning the strainer
I didn't have the appropriate "crescent tool" either, so I took a small screwdriver and while holding on to the outer orange sieve, I rotated the inner piece counter clockwise and it loosened so that I could fully disassemble the machine.
May 29, 2008 | Jack Lalanne Power Juicer 250 Watts
How do u wash this?
if you have a jack lalanne it comes with an orange handle that fits into the sharp cutter and you twist it to tighten/loosen the blade. hope this helps
Dec 04, 2007 | Juicers
This is a response I received from Champion Juicer- I am amazed at how fast they responded. His solution is below- Hello Cathy
To remove the cutter from the Champion Juicer motor shaft, take two small
screwdrivers and place them between the back side of the cutter and the
stainless steel portion of the hub. Apply pressure on the screwdrivers and
the cutter should begin to slide forward. When driving the screwdrivers in,
make sure they are spaced far enough apart so they don't damage the motor
shaft which is located in the center of the cutter. If the cutter does not
come off, leave the screwdrivers in place and insert something under the
rear of the Champion Juicer (like a book) to elevate the rear of the
machine, thus allowing the cutter to tilt forward. Apply penetrating oil
between the screwdrivers. Because the cutter is now angles forward the oil
will run inside the cutter. If this is done for several days the cutter will
come off by applying more pressure to the screwdrivers. By merely pulling on
the screwdrivers you will have to use a plastic hammer and slowly tap on
each of the screwdrivers until the cutter breaks free. Tap one screwdriver,
and when it is snug, tap on the other screwdriver until the cutter breaks
free. When this is done there will always be one screwdriver coming loose
and falling out of the slot. Do not rush the removal process; give the oil a
chance to work. It is possible the hub and cutter will be damaged during the
removal process. Contact us for current replacement prices. Once the cutter
has been removed you should polish the motor shaft to remove any film or
burrs which may have developed. If you contact us with your address we will
mail you a piece of fine emory cloth to polish the motor shaft  at no
charge. You should always apply a slight film of olive oil on the motor
shaft to prevent sticking of the cutter. Do not use other oils, as they tend
to break down from the heat during operation of the juicer. If you wish to
speak to a repair person, please call our company weekdays @ 209-369-2154
between 8:30 a.m. and 4:30 p.m. Pacific Standard Time. We would be happy to
offer any assistance you may need.
Thank you
Aug 05, 2007 | Champion 2000+ Household Juice Extractor
OPENING the JC-250 Juice Extractor
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Jan 22, 2007 | Brentwood JC-250 Juice Extractor 350 Watts
Black & Decker JE 1500 Juice Extractor Logo
50 people viewed this question
Top Black & Decker Juicers Experts
Are you a Black & Decker Juicer Expert? Answer questions, earn points and help others
