Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Turn on the TV and only Timer light is on , no sound & picture
I turn on the TV and the timer light is the only light that will come on
After a few seconds the timer light will turned off. Okay I have the same problem with the timer light coming on and then shutting off within a few seconds. I have sound but no picture. I tried holding the menu and input together and it did what you said...green timer light blinked a few times. But now what? That didn't seem to fix it. Mine is a Mitsubishi HD 1080
  • sandibradley Jan 24, 2009
    Okay after the menu and input pushed together it blinked the #24.
    What should I do next.
  • sandibradley Jan 26, 2009
    What about a 24 code?
  • Mitsubishi Master
  • 8,617 Answers
After holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Posted on Jan 24, 2009
  • Sonny Berry
    Sonny Berry Jan 26, 2009
    There is no 24 code Count the blinks again. There will be a series of blinks for the first digit then a pause then a second series of blinks for the second digit then it repeats
SOURCE: have a mitsubishi hdtv 1080
no i havent fixed it. i couldnt get help from your so called experts because i dont have a credit card to pay you so i will keep trying to get help from someone whos really willing to help .
Posted on Dec 02, 2008
SOURCE: Need a "Mitsubishi HD-1080 HDTV Receiver" to convert my TV to HD
if you are still looking for this i have 5 of them left , brand new, hit me up and can list them for you on ebay.
Posted on Jun 04, 2008
  • 6 Answers
SOURCE: my tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Posted on Dec 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Posted on Mar 13, 2009
electronick
  • 505 Answers
SOURCE: when I push the power button the timer light glows
A fuse is blown inside usually and its going into shutdown. If its f9a04 or f9a05 then its likely convergence (the most common issue). Check them with an ohm meter. Here is a tech guide, it talks more about when the tv will still come on, but it may be helpful.
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Posted on Jun 12, 2010
Testimonial: "This is great! I will go to Radio Shack tomorrow and pick up the fuses and try this out. I am so hopeful this fixes the problem. Thank you so much electronick!!!"
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
The timer and standby lights are blinking at the same time. TV turns on for a few seconds then turns off. Both fans turn on when the TV turns on and off when the tv turns off. Any idea what might be...
The problem if you television is in the power section.The power suppy shutoff because they have leak parts like capacitor and transistor.Its better to troubleshoot the power supply.Thanks
Jul 09, 2011 | Samsung DLP HL-P5663W 56" TV
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
On/off green light flashes. Picture comes on for
the timer is set for a short time, try to get to the menu quick and turn off the timer it may take several tries.
Mar 06, 2010 | Televison & Video
Blinking timer light and cannot turn on
How many times does the LED blink? Does it blink 6 times, pauses, and repeats? Or is it some other number of blinks? Or does it just blink continuously, once a second? (Note: on Mitsubishi's it is normal for the TV to blink rapidly for about 90 seconds after you plug the TV in, while the TV runs internal self-tests.) If the LED continues to blink continuously after 90 seconds, then the problem is on the DM board. There are 4 electrolytic capacitors, grouped together. I believe they are either 820 uF (mfd - microfarads) or 1000 uF at 16 Volts. If you check them, you will see that their tops are swollen (slightly rounded; not flat across). They will check okay with a capacitance meter or ESR meter, but don't believe your meter! Replace those 4 capacitors with either 820 or 1000 uF capacitors rated at either 16 or 25 volts. Make sure you use good, high-temperature (105 deg C) low-ESR capacitors. I recommend the "FM Series" capacitors from Digi-Key corporation, part number P12366-ND or P12379-ND. Less than $1.00 apiece. Good luck!
Dec 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Jan 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Aug 23, 2008 | JVC AV-32260 32" TV
Panasonic TV/VCR combo
Shop time. Plan on spending 75 to 125 dollars for power supply worl...accordianman
Feb 28, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
