Question about LG VX3400 Cellular Phone
Works Only When Plugged In
Won't turn on when unplugged, when on charger everything works as it should. Shows that the battery is fully charged. As soon as it is unplugged, it goes completely dead. Plug it back in and viola' it works fine. Not a problem except it is supposed to be a MOBILE phone.
  • Anonymous Nov 22, 2007
    I have the same problem.
  • Anonymous Sep 07, 2008
    phone only works when plugged in
    help!
Me too. just started today. i had let the battery run down all the way. i tried taking the battery out but that didn't help.
I also accidentally dropped it in my coffee this afternoon, after the battery ran out, so that might have something to do with it.
Posted on Jan 25, 2008
SOURCE:
Camcorder not working without charger plugged in.
hi if you have the charger plugged in the camera the you have power to work it, if you unplug the charger and it dose not work, the I think the battery is not charged fully or it is no good after being left to long, check to see if the battery is charged. I hope this helps you, please let me know.
Mar 30, 2014 | Sony DCR-DVD602E DVD Camcorder
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
My zune 4g red will turn on and work when plugged into the charger, but as soon as I unplug it from the charger it goes off and I cannot do anything with it. I haven't tried to restore it, not sure...
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 29, 2011 | Audio Players & Recorders
My garmin 205w only works if it is unplugged from the charger but only holds a charge for about 15 minutes. if it is plugged in it shows a screen that shows the unit plugged in to a computer tower. Any...
Sometimes the satnav goes into mass storage mode, when plugged into the charger, and shows the unit connected to a computer because the charger plug is not pushed in fully to the back of the satnav. It appears to be fully in but it's not. Pushing it in further may solve the problem.
May 30, 2011 | Garmin nuvi 205W GPS Receiver
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
Wont turn on unless its plugged into the charger.
maybe their is a faulty with the battery of your phone replace phone battery with another phone with same phone model...if it works fine then just replace to a new battery....or else visit any phone technician to handle it for you.
Oct 28, 2009 | SanDisk Sansa Clip MP3 Player
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
LG VX3400 Cellular Phone Logo
157 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
