Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Strong sucking in hose
We have the DC17. Every time I try to use the hose, the suction is so strong that it sucks the hose right in and it is not useable. Could it be a blockage??? I wouldn't even know where to begin if it is...
Thanks in advance for your help!!
  • 1 more comment
  • Heather Jan 23, 2009
    It was a blockage. Thank you!!
  • cavery49 Feb 08, 2009
    The hose sucks in on itself, collapses. I turn it off and the hose relaxes. I have removed u-shaped connector and found no blockage there.
  • Anonymous Feb 13, 2009
    I have the same problem on a 25 ball animal, how do I dismantle it to remove blockage please?
    President:
  • 1,214 Answers
Sounds like either the stiffeners within the hose have failed, or there is a blockage as you mentioned.
See if the hose feels weak at the point where it collapses. If not, look for a blockage in the vacuum head, or remove the hose at the vacuum head end and look for a restriction in the hose or the vacuum head port.
Posted on Jan 23, 2009
I love the machine because it sucks up the dirt but it also sucks up the rug fibers and is clogging the hose. How to I clean out the hose?
Try this - run a strong string with a small weight attached down through the hose. Tie a small rag or a sponge to the end of the string and pull it back through the hose.
Dec 04, 2016 | Vacuums
When bissel turbo steam cleaner wont suck
google it:
My ProHeat 2X® is not suctioning properly. What ... - Bissell
www.bissell.com/faqdetail.aspx?id=1124 BissellAnswer: Let's start by figuring out where your carpet cleaner has suction. Check for ...If the Lint Screen is dirty, the suction won't be very strong. Cleaning the
Jul 20, 2015 | Vacuums
Loss of suction to the hose. All hose lines appear to be clear.
Have you tried reversing the hose-- and sucking on the outlet end?-- this might assure that the hose is unplugged--
Or is there ot enough suction at the hose connection, when you remove it, and place your hand over the opening?
WHen did you change filters last on the upright?-- or at least clean the filters?
Mack B
Dec 28, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
The suction of the hose has become so strong that it becomes crinkled and will not pick up.
you have blockage before the w and all rinkle in the hosethe vacuum is between motor and blockage
Mar 05, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
The suction in the hose of my 2 year old Dyson Animal vacuum is compromised. I may have sucked up a small cat toy or something. Regular vac still is fine. The hose "sucks closed" after a few seconds near...
Hi there, it sounds as though the wand handle is blocked. To test this, remove the wand handle from the hose and test the suction at the top of the hose. If its strong here, then you will need to remove the blockage from the wand handle. If the suction is still poor, you will need to remove the hose by pressing in the catch on the hose cuff near the base of the machine and removing any blockages.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Dec 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suction from hose isnt strong enough. Vacuum
There is probably a clog on the U channel (little Gray tube that attaches to the Vac tubing). Pull it loose and look in side all the tubing.
Nov 16, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hoover tc5238 bagless cylinder vacuum cleaner - no suction
You have a clogged hose. Sometimes a Q-tip or something like that gets sucked up and then stuff jams up against it. You can use a long stiff wire with a hook bent in the end to reach the jam and work it loose. Just be very careful not to poke the wire through the hose! Work slowly and get the clog out a bit at a time.
The clogged hose would also account for the red light.
Apr 08, 2009 | Vacuums
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
220 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
