Question about IBM 4247 A00 Matrix Printer
Can hardly read print after putting on new ribbon
We have an IBM 4247 which prints from an AS400. The print on the left side of the paper is very light and you can hardly read it, it looks almost blurry. The prints gets a little darker on the right side of the paper. When the printer starts printing there is a loud popping noise. This has just started last week. We changed the ribbon, thinking that it was the ribbon, but it is not. Do you have any idea what is causing this? We have a second printer and we are switching all of our print to that printer at the moment.
You have to make a platen adjustment (on the left side move it back).
Posted on Apr 14, 2009
Light printing
The head gap is too far..then you need to adjust the small wheel with the numbers on your left hand side of your carriage bar or shaft..if not possibly the ribbon must be changed.
Jan 12, 2011 | IBM 4247 A00 Matrix Printer
IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Feb 18, 2010 | IBM Office Equipment & Supplies
IBM Printer 4247 in Parallel Mode
They are auto switching units. All you have to do is configure it correctly and send a job, it selects the interface your are printing thru.
If you have any questions or if you are looking for parts for this unit please contact me back.
Thanks
Rory Cardenas
Midrange Repair and Parts
3821 W. 127th Place
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 02, 2009 | IBM 4247 Model V03 Matrix Printer
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
Printer setup
Continuous forms paper fed through the front of the printer also uses either the Front Push, Rear Pull, or Push-Pull tractor configurations. Make sure this is set correctly or it will reverse your margins.
It could also be your software. When you print through windows it's using the Microsoft system font controller, but your software could be setting font, margins, and alignment by the settings in the printer not in the driver. So if the first doesn't work, set your system back to align left then go into the printer configuration menu on the device and adjust the margins there.
Dec 15, 2008 | IBM 4247 Model V03 Matrix Printer
Fix page printing
Not Familiar with this printer particularly But if you reduce 'paper' size presumably the printer will reduce the image to fit. Did you try that?
Aug 27, 2007 | Lexmark 2381 Plus Matrix Printer
Ibm 4247-a00
Are you using paper with a black patches on it ?
If not you have one of the following :-
a . Faulty paper sensor
b. Faulty Logic Board
c. Faulty sensor cable.
Aido
May 04, 2007 | IBM 4247 A00 Matrix Printer
IBM 4247 A00 Matrix Printer Logo
335 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
