Miele W1926A Front Load Washer Logo
A
Anonymous Posted on Jan 13, 2013
W1926 Do I put the liquid detergent on the left side and the powder on the right?
1 Related Answer
Anonymous
  • 43501 Answers
  • Posted on Aug 05, 2011
SOURCE: The detergent dispenser won't open
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
1helpful
I just got a Samsung 4.5 cu. Ft hi-efficiency front load washer with self clean+in white . The book that came with It doesn't have pictures or much instructions.
This could be a Samsung WF45T6000AW washer. On this model (and most similar recent Samsung front-load washers), the dispenser drawer is to the left of the cycle selector dial. When you pull out the drawer, the compartment arrangement is: front left - liquid detergent, front right - liquid fabric softener. Liquid bleach goes into the back compartment. If you are using a powdered detergent, you have to remove the liquid detergent container. It just lifts out. Then put the powdered detergent in the front left- compartment.
I found the Use and Care manual on the product page, https://www.homedepot.com/p/Samsung-4-5-cu-ft-High-Efficiency-Front-Load-Washer-with-Self-Clean-in-White-WF45T6000AW/313846213 , at HomeDepot.com. The current link to this manual is https://images.thdstatic.com/catalog/pdfimages/1d/1d90b4de-ebaa-4d5f-a0cf-494bb1ffd212.pdf . The use of the detergent drawer is covered on pages 28-30. The description of the washer control panel starts on page 31. The cycle overview starts at page 35.
I hope this helps.
Hi,where do you place powder for normal wash, left side or right side
In the uk a normal wash would want powder to the left side of the drawer.
2answers
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
2helpful
Which side of the dispenser does the detergent go?
The detergent goes in the front left side,their is a blue cup their if using liquid,pour it into that cup,if using powder detergent remove that cup and the powder goes there. The Bleach would go behind the detergent& and softner would go in the right rear compartment
Gene
2answers
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
1helpful
With a whirlpool front loader, the tray you put the washing powder in has 3 compartments what goes in which compartment
If the model number you have this question listed under is correct, the Duet dispenser tray is arranged as follows:
1. The LEFT compartment is for detergent. There is a separator guide that needs to stay in place. Place it in the forward most position if using liquid detergent and the aftermost position if using powder.
2. The RIGHT FRONT compartment is where you put liquid fabric softener.
3. The RIGHT REAR compartment is where you add liquid bleach.
An illustration with full explanation is available on Page 12 of the Whirlpool Duet owner's manual. If you no longer have a manual, you can go to managemylife.com and download or print a copy for FREE.
If you have any further questions, or if your model number is different, please post back and let me know. I hope you find this information helpful.
9helpful
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
36helpful
Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Soap
As you look at the despenser drawer it has 3 chambers. The left chamber is for Prewash detergent, middle for Fabric conditioner, right is for Liquid or powder detergent. Or use a plastic ball in the main drum!
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
