Question about Frigidaire FRS26F4C Side by Side Refrigerator
My freezer is defrosting and the frig is squealing intermittently,
It has never done this before. I'm worried the compressor is going. Everything in the freezer is defrosting and water is running out of the freezer even when it is closed. The fridge works fine. I vacuumed the back side but it is still blowing in the freezer but evidently its not freezing. Any ideas? 1angel
  • angel henry Jul 08, 2007
    The sqealing is coming from the right side bottom of the fridge.
Same exact problem is happening to mine. Did you find out what is causing it yet?
Posted on Aug 10, 2007
Same problek
Posted on Nov 12, 2008
SOURCE:
Have extra older Frig in th garage Mod 596.72232200
Sounds like a intermittent problem with the defrost timer. Sometimes they get stuck. Check continuity of the defrost heater and defrost thermostat. If both are good then replace the defrost timer, that should solve the problem.
May 30, 2014 | Refrigerators
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
The freezer stopped working but the frige seem fine. no ice build up on the defrost timer.
No model # given to reference the symtoms. I would surly worry if you had ice buildup on the defrost timer. Some are in the fresh food side and some are outside the compartments. Extreamly rare to have one in the freezer.
Also if this is a standard SxS or top mount system...everything that happens in the fresh food section, happens because of the freezer. Air moves from the ff side to the freezer. The air is cooled down and recirulates back through the freezer and to the ff side. Issue could be ...evaporator fan bad or low RPM, freezer door switch, cold control not cycling on / back on. Compressor intermittantly cycling / bad start device / weak compressor, condenser fan slow or not cycling...should be on anytime compressor is running. Some of these items can be visually checked, some require advanced knowledge and a multimeter for test. Be careful of live voltage and sharp edges.
Ric
Mar 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator is stuck in defrost mode.
If the compressor is running and not getting cold I would say that you have burnt out your compressor.
If it was stuck in defrost you wouldn't hear the frig running. When in defrost the compressor stops while the frig defrosts.
Dec 29, 2009 | Refrigerators
Freezer has stopped
If it is a frost free side by side fridge/freezer, check evaporator fun in the freezer. While doing that, check is evaporator is full of ice.
if the evaporator is iced up and the fan can spin freely, you have a broken fan. Replace it.
If evaporator and the fan are iced up, you have a broken thermostat. Defrost ice with hot water.
Turn it on, if it starts to cool effectively, replace thermostat.
Oct 11, 2009 | Refrigerators
I need to change my defrost timer as the fridge side is not working
For those who had the control board replaced or are experiencing the frig side warming while the freezer side continues freezing; The problem may (still) be a faulty control board. I fixed the issue by replacing a $1.00 capacitor on the board. I'm not a techy and it wasn't too difficult to solder. More info on what to do here; DIY Chatroom
In the mean time defrost the ice that is blocking airflow and causing the frig to warm. Check behind the lower panel inside the freezer.
I use a pump pressure garden sprayer with hot water to defrost the coils. Gets the job done in 20 minutes and I don't have to worry about defrosting items in the freezer.
Jul 14, 2009 | Maytag MZD2766GES Side by Side...
Refrigerator and freezer not cooling
sound like side by side check compressor for starting up check defrost timer
May 30, 2009 | Viking DFBB363 Bottom Freezer Refrigerator
Compressor
You may have a problem in the evaporator fan . Defrost fridge for 24 hours and start up. Problem should go away for some time. For a long term solution you need to check if defrost cycle is funtioning well if not suspect the timer or the heater.
Sep 25, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Lights are on but nothing else
Checked the switch in the freezer and it was bad. Odd time for it to go out, but it was not working and it would work intermittently if you shook it.
Jun 10, 2008 | Amana ARB8057CSR Bottom Freezer...
Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Frigidaire FRS26F4C Side by Side Refrigerator Logo
123 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
