Question about Zebra P330i Thermal Card Printer
Cannot find n5lpt.sys
Generic error when printing
AUS cm6780 BSOD ERROR 0x000007E
Debug session time: Mon Jul 14 09:57:27.345 2014 (UTC - 4:00)
Unable to load image atikmdag.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8800f4d0dbb, The address that the exception occurred at
Arg3: fffff88008f85228, Exception Record Address
Arg4: fffff88008f84a80, Context Record Address
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 00000000000006a8
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80003702100
00000000000006a8
FOLLOWUP_IP:
atikmdag+c7dbb
fffff880`0f4d0dbb 488b83a8060000 mov rax,qword ptr [rbx+6A8h]
BUGCHECK_STR: 0x7E
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff8800f4d0dbb
STACK_TEXT:
fffff880`08f85460 00000000`00000000 : fffffa80`0ac95a80 fffffa80`09c35840 00000000`00000003 fffffa80`0d6c9010 : atikmdag+0xc7dbb
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: atikmdag+c7dbb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME: atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 53508a3c
STACK_COMMAND: .cxr 0xfffff88008f84a80 ; kb
FAILURE_BUCKET_ID: X64_0x7E_atikmdag+c7dbb
Followup: MachineOwner
2: kd> lmvm atikmdag
start end module name
fffff880`0f409000 fffff880`10319000 atikmdag T (no symbols)
Loaded symbol image file: atikmdag.sys
Image path: atikmdag.sys
Image name: atikmdag.sys
Timestamp: Thu Apr 17 22:13:16 2014 (53508A3C)
CheckSum: 00EAEEE6
ImageSize: 00F10000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
Uninstall and reinstall the current driver and if no joy, Try and older version, but nothing over 1yr old. If still not working, try a BETA version if available.
Can't Find Your Driver or Don't Know What Driver to Choose? Please Read This First.
http://support.amd.com/en-us/kb-articles/Pages/find-a-driver.aspx
AMD Graphics Drivers and Software.
http://support.amd.com/en-us/download
***Some generic information on Bug Check 0x7e.***
Bug Check 0x7E: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED.
http://msdn.microsoft.com/en-us/library/windows/hardware/ff559239(v=vs.85).aspx
Resolving stop (blue screen) errors in Windows 7.
http://windows.microsoft.com/en-us/windows7/resolving-stop-blue-screen-errors-in-windows-7
***See if this "HOTFIX" below Applies.***
Stop error message in Windows 7 or Windows Server 2008 R2: "Stop error code 0x0000007E (SYSTEM_THREAD_EXCEPTION_NOT_HANDLED)" or "Stop error code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA)"
http://support.microsoft.com/kb/979538/en-us
Machine ID Information [From Smbios 2.7, DMIVersion 39, Size=3043]
BiosMajorRelease = 4
BiosMinorRelease = 6
BiosVendor = American Megatrends Inc.
BiosVersion = F7
BiosReleaseDate = 01/20/2014
SystemManufacturer = Gigabyte Technology Co., Ltd.
SystemProductName = Z87-HD3
SystemFamily = To be filled by O.E.M.
SystemVersion = To be filled by O.E.M.
SystemSKU = To be filled by O.E.M.
BaseBoardManufacturer = Gigabyte Technology Co., Ltd.
BaseBoardProduct = Z87-HD3
BaseBoardVersion = x.xGigabyte Z87-HD3
http://www.gigabyte.com/products/product-page.aspx?pid=4489#dl
Remove.
fffff880`0476f000 fffff880`047b7000 dtsoftbus01 (deferred)
Image path: dtsoftbus01.sys
Image name: dtsoftbus01.sys
Timestamp: Fri Feb 21 04:49:36 2014 (53072130)
CheckSum: 00047544
ImageSize: 00048000
Driver Description: Daemon Tools driver
Possible BSOD issues in Win7
I would also suggest you remove AVG Completely and replace with Microsoft Security Essentials.
Jan 12, 2015 | Computers & Internet
Missing Usbccgp.sys
What is usbccgp.sys?
Microsoft USB generic printer driver system driver file. This usbccgp.sys file is safe and should not be considered threat to your computer.
Download this update from this link and install:
http://support.microsoft.com/kb/814560
Otherwise uninstall and reinstall the printer driver (if you have any) on your PC.
Sep 23, 2012 | Computers & Internet
I'm installing XP till Windows 7 comes in the mail. I can't get to the load screen where it gives me the option to install after the CD is done loading the generic drivers. It either stops...
did you check to see if your board can be used for that system first some boards can not use those systems.check harddrive for format format drive then reinstall system ok jim
May 15, 2011 | MSI 880GME43 Motherboard
Ink sys failure error message
Try the following steps and check if it resolves the above error.
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
Wish
Aug 01, 2009 | HP Photosmart D7160 InkJet Printer
Printng error
Please change the driver to UPD (http://www.hp.com/go/upd) to PCL5
This will solve the issue
Rgds,
Nikhil
Jun 14, 2009 | HP LaserJet 1320n Printer
Ink error
did you use some generic cardridge? some of the cardridge have memory chip and the generic, whatever they say, are not always compatible
Feb 04, 2009 | HP DeskJet F380 All-In-One Printer
PCL XL error
Please uninstall the current PCL driver and upgrade the same with UPD PCL5 (dont install PCL6) from http://www.hp.com/go/upd
Regards,
Nikhil
Dec 16, 2008 | HP LaserJet 1320n Printer
ERROR CODES
The following are generic OBD II codes so your Sabb may not conform:
P0507=Idle Control System RPM High
P2187=Sys Too Lean at Idle Bank1
Oct 06, 2008 | 2004 Saab 9-3
Print failure error # oxyc19ac3ff
oooh too bad.. did you get that error # oxyc19ac3ff? on what printer model? that would be ink sys failure. might as well buy new printer or if your still in warranty then ring hp and have it replace
Apr 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Zebra P330i Thermal Card Printer Logo
252 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
