Canon PIXMA MG5370
Ink refill
SASSYBEAR
  • 148 Answers
SOURCE: Ink Cartridge Refill Error E5
press and hold (stop/reset) for at least 5 seconds, then release it. It will tell the printer that refilled ink tanks are installed. Therefore, allowing printing to continue.
Posted on Mar 15, 2008
cropp
  • 377 Answers
SOURCE: canon mp150 pixma printer error e5
dear warenout
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
  • 183 Answers
SOURCE: Hi, my canon pixma mp210 shows
Dear cappina,
Error code E16 indicates that remaining ink is unknown. It is common problem in refilling the cartridge. To fix this problem you need to deactivate ink level detection function. Follow this procedure: press and hold STOP/RESET button for about 9 seconds or more then release it. Now E16 has disappeared and the printer should work properly. As consequence, ink volume in panel become UNKNOWN. No problem. It will be back to normal condition when you replace the cartridge with new one.
Regards,
Source:
Canon Inkjet Forum
Posted on Dec 11, 2008
SOURCE: My Canon Pixma MP220 is
Same thing happened to my MP220. U051 chk Blk and Colour. I got my colour one replaced as there was an electrical fault in it. So the solution is to replace whichever one has the electrical fault or both and it works just fine. Refilling only works for a certain number of times. 4 or 5 at most and mine only lasted 1, so not always successful.
Posted on Feb 18, 2009
pineworks
  • 4041 Answers
SOURCE: Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Posted on Feb 18, 2010
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
Error 5B00 in canon pixma MG5370
Hi ..
Try to Reset Printer Ink Obsorber..
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. The green led light should come on.
  4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
  5. Release the Power button.
  6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
  7. Turn off the printer and then turn it on again
Apr 06, 2014 | Canon Pixma iP6210D InkJet Photo Printer
Canon PIXMA MG 5370 Ink All-In-One Printe b200 problem
cara memperbaiki error b200 di printer canon mg5370?
Dec 13, 2013 | Office Equipment & Supplies
Canon pixma mx350 printer ink level shows exclamation mark about the icon
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
Nov 20, 2013 | Canon PIXMA MX350 Wireless All-in-One...
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Feb 22, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I have a Canon PIXMA iP100 printer. I refilled my Canon PGI 35 ink tank and the sensor did not reset so it still says that it has no ink. Is there a way to reset the sensor so the cartridge will work?
Nope. The ink levels cannot be reset on refills for this type of cartridge. As long as your printer still prints you should be good. If it doesn't print you either need to go get another refill or a Canon brand cartridge.
Dec 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma refill is not recognized
Dear nedaa,
You need to deactivate ink level detection function to keep your printer working after refilling the cartridge. Click here to know more how to deactivate ink level detection function.
Source:
Canon Inkjet Printer Forum
Canon Manual & Tools Dowload
Jan 17, 2009 | Epson Stylus 2200 InkJet Photo Printer
Canon Pixma MP950 Ink Refill Error
replace the cartridge with a Canon as the chip has gone on the cartridge.
this is the only way around it with the mp950.
This is to stop them being refilled
May 22, 2008 | Canon Pixma MP950 All-In-One InkJet...
Printer ink
hello laylawoman
if this is the right ink then it seems they do sell refill kits .
canon pixma mp150 ink cartridge and canon pixma mp150 ink refill
i would check on line for better prices .
riz.
Mar 10, 2008 | Canon PIXMA MP150 All-In-One InkJet...
500 people viewed this question
k24674
jasbo
jasbo
