Question about PC Connection FastCAT 5e Patch Cable (350002AB)
Connecting pc to grundig32 tv - msg out of range
Trying to connect pc to tv with direct cable. msg on tv - out of range. Have changed long lead for short lead - no difference.
What am I doing wrong?
    President:
  • 1,214 Answers
I am going to suggest with that message, the the TV does not understand the signals it is getting from the PC.
Reboot the laptop while connected to the TV, and turn the TV off, then On, while the PC is connected. If you continue to get the message, look in the manual for the TV to determine the reason for the message.
Posted on Jan 23, 2009
    Scholar:
  • 140 Answers
Out of range is not refering to your cable distance. It is refering to the resoultion that your computer is outputing.
Try adjusting your settings to a lower resoultion in the display section of the control panel. Set it on something low like 800x600 and your refresh rate at around 60hz. If this works then you can increase your resoulution unit the tv stop responding and the back off one.
Normally your tv user manual will tell what resolution setting your television is capable of. Just make sure your computer is putting out the poper signal.
Connecting Sony Bravia TV to Dell Dimension 5150
Have you selected the PC setting on your TV? and set the resolution on your computer graphics to one that is relevant and usable by your TV.
Aug 21, 2013 | Dell Computers & Internet
How to hook up a panosonic 50" Flat screen plasma
Try connecting TV to DVD with a scart lead or a hdmi cable now hdmi v cables are the next best thing from a scart lead
Dec 21, 2011 | Televison & Video
Connect to netbook to lcd tv
hi mate what you need to connect your netbook is an vga cable which you can buy at asda or home bargins etc.
2 you wil need to get a audio lead which plugs in to your tv
this audio lead will need to have a red and yellow plug in which goes into your tv the other side is just like an normal black audio plug in like speakers
http://direct.asda.com/ASDA-VGA-Cable/000596699,default,pd.html
Aug 02, 2011 | Acer Aspire One PC Notebook
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Blue picture
It is your "vergin media box" outputting a blue screen!
When this TV has no input it displays a msg box "No Input Signal" or "Signal out of Range" (PC video resolution is not correct.)
Jun 26, 2009 | Hyundai Electronics E465D 46 in. LCD TV
Got samsung le37a456c us as monitor
This samsung as pc monitor has an easy solution. after trying everything on many different sites:- rebooting, locating tv in settings, all the different sequences of conecting and turning pc and tv on, resolution settings. all this was a complete waste of time. SOLUTION:- i read all these people with the same problem and many had tried laptops and pc's on same tv yet always using same vga lead. so i decided i'd look at problem not in pc or tv but the lead, i borrowed a vga lead from I.T. department and as soon as i plugged this lead into my samgsung tv my pc option was active and i'd not even connected pc at that point. so i know its a total lead oriented problem.
Mar 27, 2009 | Samsung Televison & Video
Ive connected the vga cable and still get "NO SIGNAL" msg.
If the resolution of the source of the RGB signal is outside of the range of the set, you will get this mesage. The supported resolutions are listed in the owner's manual. Verify that you have a signal within that range. If you do, please post your source of the video here and we'll look further.
Thanks,
Dan
Mar 19, 2009 | Vizio VOJ320F1A 32 in. LCD TV
Trying to connect my pc to a wharfedale lcd37f1080p using the standard moniter cable and am getting the message !out of range! on the tv
Change you screen resolution to lower resolutions, like 640x480, connect it. if you get video, move your resolution up and test which ones work for you TV. Try to stay under 1920×1080.
Dec 07, 2008 | Computers & Internet
HOOKING TV UP TO CABLE DIRECT TV MITSUBISHI VS 412 R
Check tv is set to pal or ntsc....it has to be the same as the output if the box.Then check the connections...have you a different hdmi lead as sometimes the lead is the wrong class....also try a different output slot or input slot to tv....change the av input or tv menu....do not use the tv to tune the box...you need to set the tv to the right av input for the box...then use the box menu to tune the box.....finally if the picture is still snowy then it has to be the dish alignment...or the cable between the dish and box connections is not tight enough.
Jan 11, 2018 | Televison & Video
Plasma tv connection to pc
when you say you have even changed the settings to pc...do you mean you have used PC..to try connect...through settings..??
I would have thought on the remote there is a button for setting up the Plasma TV? you checked to make sure there isn't a menu where you can tell the TV its connected to a PC??
It may be you will have to switch between the two. My reason is that on my TFT..there is a menu....when I check the list..there is an option to connect to PC..AV1 AV2.
With your lead connected you should get something?
hope helps
Feb 13, 2008 | Computers & Internet
PC Connection FastCAT 5e Patch Cable (350002AB) Logo
1,062 people viewed this question
Top PC Connection Computers & Internet Experts
David Payne
David Payne
Are you a PC Connection Computer and Internet Expert? Answer questions, earn points and help others
