Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
The uf585 takes in more than one sheet at a time
  • 2,120 Answers
Open up the toner door
Hopefully the sep pad holder is still in the machine:
pull the operating panel up until it stops
remove the one inch wide blue tab by pulling it out
turn the rubber pad over.
reinstall blue tab..rubber part goes down
close operation panel
close toner door
Posted on Jan 24, 2009
Two sets of sheets and the dryer wads the sheets in a ball and takes forever to dry. Then I untangle them and try again and still the same wadding up. Checked with other front loader owners and it...
I have Design a new solution it is the Dwadder.
Dwadder made from HDPE plastic. The Dwadder is the first ever Dryer Device that does dry your sheets and blankets faster! The Dwadder keeps your sheets and blankets from wadding up in the dryer. This will save you Time and Money when drying. Dwadder can cut your drying time up to 30 mins or more. Two sheets or blankets can be strapped to the Dwadder at a time to keep from wadding up in the dryer.
One of the most time-consuming uses of a dryer is drying blankets and sheets. The reason it takes so long is the blanket or sheet can be twisted into a tight wad or ball during the drying cycle. Once this happens the dryer is incapable of drying the center of the wadded blanket or sheet. The solution today is to take the blanket or sheet out of the dryer halfway through the drying cycle and unwad the bundle of sheets or blankets. Then place the blanket or sheet back into the dryer to restart the dryer cycle over and over again until the blanket or sheet is dried. If you forget to unwad the blanket or sheet when you get ready to make the bed, the blanket and or the sheet will be wet.In order to fix this problem, the Dwadder is strapped to the sheet or blanket using a silicone cord before it is placed in the dryer. Once the dryer is started the blanket or sheet will wrap around the Dwadder allowing a space to be in the center of the blanket or sheet. With the space that is created by the Dwadder the center of your blanket and sheet will dry faster and will not roll into a tight ball or cylinder shape. This will help save time drying your sheets and blankets. The device will also prevent wadding of your sheets and blankets so you don't have to unwad your blankets and sheets half way between the drying cycles.
How to Use the Dwadder
Simply pull half of your blanket or sheet out of the washer. Then pull the silicone cord to slide the blanket or sheet between the silicone cord and the Dwadder. Slide the Dwadder to the center of the sheet or blanket then put your blanket or sheet in the dryer with the Dwadder attach to your blanket or sheet. You can use both silicone cords for two small blankets or sheets just don't place 2 blankets or sheet on top of each other or it will take longer to dry. For Video instructions please go to the website at or Youtube.
Apr 02, 2011 | Samsung DV337 Electric Dryer
My UF585 said printer error info code 021. Please tell me how can fix it.
monitor key slowly 4 times
* star key
scroll down to SHIPMENT SET
wait for reboot
Feb 05, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Info Code 054 - Printer Error - cannot be found in manual
sorry to tell you its the lsu laser unit in the machine the only way to fix it is to replace the part
Dec 08, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Look for manual
If you go to this web page.
you can find the manual to download.
Hope that helps...
Aug 15, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax uf585
there might be an incomlete file waiting to be sent again in which case the last document will go into a que and be delayed. (maybe) you can retry the docoment again by pressing the memory button and sending directly, press the monitor buttonfirst and listen for dial tone, the send
Apr 17, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panasonic UF - 560: Comm Journal page does not print
I could not find to the manual for your particular model, however the following should be close enough. Although you have set the Comm Journal to "On" you have to set the paramater to "Always" Download the manual at: Look at page 131. I think that will take care of it. IF NOT - PLEASE let me know before you rate this solution. I will research it further. Ed
Jun 28, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
