Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Cold air coming from the intake of the central a/c unit. The unit is switched off and it is winter, so why would cold air come from the intake
    Novelist:
  • 88 Answers
Thanks for your question,
Just a couple of questions first, is your ducting insulated ? is there a fresh air intake on your system ? if either of these is the case, the first would be that you need to have your duct insulated, it is good practice to have them insulated as it will save you money down the road as to not have as much heat loss or cold air from the duct escaping into the home, second if you have a fresh air intake, alot of times that is where fresh outside air would be coming in from, there should be a damper on the venting, if there isn't I would suggest having one installed, normally it is installed on the return side of your ducting. Hope that was helpful, please leave some feed back as to how we did, thanks again,
mr.grzz
Posted on Jan 23, 2009
Central heating and air fan not working
it may have frozen and loosened someting it might just need to be seviced
Feb 27, 2014 | ATP HVAC - Heating, Ventilating, and Air...
Have installed air raid cold air intake system on 2006 Colorado in spring first cold night off fall having new system exp eng fault code dtc po 128 could intake temp be causing issue
Sorry, but this is an engine coolant system air temperature problem which could be a mixture of the abundance of incoming air mixed with engine coolant actual temperature and its freaking the PCM out. Which you do not want during the winter months. If you have the other air box to just reinstall it, if just for the season. You want to know your vehicle is 100% during the cold weather to prevent long cold walks. Plus yyour getting plenty of cold air during winter anyway.So just but everything back for now to just change it back over during the spring this is a simple problem glad to help.Thanks in advance please remember to rate and leave testimonial this is how we get our milestones on FixYa and please remember we are volunteers here we receive no payment and work jobs too so answers may not come as fast as you like please be patient with us. Thanks for using us the FixYa team.
Sep 25, 2013 | Motorsports
Indoor fan blowing cold air when on heating
The indoor fan will continue to run. When heat pump goes into defrost the outdoor fan stops, the reversing valve switches and the unit is basically working in the cooling mode. In order for you not to feel a blast of cold air in the winter the electric strip heat also comes on so the indoor fan must run while the strip heaters are on.
Jun 03, 2010 | Heating & Cooling
The last time i used my ac here in las vegas nv. was july 2009 and it was freezing. i terned it on to check to see if it still blew cold and it dosnt. blows air fine but dosnt get cold, is there a re-set...
central air or window unit? central systems use a low/high pressure limit switches which self reset when pressures are nominal. suction about 50-60, high pressures around 300.
Oct 20, 2009 | Heating & Cooling
When activating locking, it unlock straight away
replace the master door lock switch.
Sep 17, 2009 | 2001 Ford Focus
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
No cold air coming from the registers.
If your compressor is running outside (low hum noise) then your probably need freon .If the compressor is not running could be a bad cap or bad compressor
May 22, 2009 | Heating & Cooling
I have central air and heat(the unit is about 8 yrs old)..when my heat kicks off there is still extremly cold air continually coming through the vents as if there is still a fan going,but it's not from the...
Does it look like a box with four flex ducts or pipes coming off of it? if so its a fresh air/ heat recovery ventilator, supposed to bring in fresh air, keep in mind, the outdoor unit does not bring in air, it is just a pump to the indoor unit. that unit may be running independently, or wired incorrectly
Jan 17, 2009 | Fantech AEV1000 Air Exchanger 120 cfm
Cold air
is it a heat pump or straight electric heat??
Sep 30, 2007 | Amana AAC051FRB Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
258 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
