Question about Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
Hi i have a brother 2820 fax machine says change toner ctg we replaced
toner ctg(brother genuine) but still getting error and machine not working
donald
  • nan2188 Feb 04, 2009
    I replaced the toner in our Intellifax 2820 with two new toners and it still says replace toner and will not work.
  • george_40 Mar 31, 2009
    dust on drum . says to remove dust from corona wire?
  • 215 Answers
With machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
What we can do for brother fax-2820 " DRUM ERROR"
open front cover with the machine on and press the options key.message will appear replace drum unit then select 1 for new.close cover
Oct 25, 2012 | Brother IntelliFax-2820 Laser Fax
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
Jan 26, 2011 | Brother Office Equipment & Supplies
I change the drum for my fax machine, but it still says Toner Life End... and it is a bran new cartridge?? I tried turning it off and on, and unplugging it... but it still says Toner Life End... how do i...
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Brother IntelliFax-2820 Laser Fax
Hi. We have about 6 of the Brother 2820 fax
CAN U PLEASE CONTACT ANY SERVICE CENTRE NEARBY U,
May 25, 2010 | Brother IntelliFax-2820 Laser Fax
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
Can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Brother 2820
The toner cartridge is in the drum unit. push the blue lever and the toner pops out, make sure you have a toner cartridge in the drum unit. Lawrence
Apr 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
1,999 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
