Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
Need instructions for Jabra bluetooth...don't see my model type.
Blue light is on (rectangular) - silver edge, black body, "Jabra" written in silver at bottom of earpiece. Can you give me a link to the instructions. My cell has "found" the device. I don't know how to work it. How do I go use voice command?
  • Anonymous Feb 05, 2009
    i dont know the code to connect my blue tooth to my phone
5 Suggested Answers
SOURCE: Problem facing with paring Jabra BT125 bluetooth with Nokia 6300 handset
http://jabra.pairx.co.uk/?l=28&pp=608
This is the tool to pair.
Njoy,
Kailash Rele
Posted on May 20, 2008
  • 25 Answers
SOURCE: Jabra vbt185z difficulties using voice commands
go to your phone tools and find voice command blue tooth and follow prompts . its all in the phone . the tooth is run by the phone. your blue tooth is only a reciever, the phone is the boss. good luck
Posted on Jan 25, 2009
  • 5 Answers
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Posted on Jun 29, 2009
jazzbassist
  • 4 Answers
SOURCE: Jabra BT2050 Bluetooth Headset not found on cell
Try pairing it again. Make sure Bluetooth is enabled on phone, turn the BT2050 on by pressing and holding the side power button. Then, press and hold the center (round) button for at least 10 seconds (light will stay solid and it is now on pairing mode). Follow instructions on your phone. Hope this helps.
Posted on Dec 16, 2009
Testimonial: "It worked! thanks a lot =P"
casouzaj
  • 1118 Answers
SOURCE: Dont know how to put jabra bluetooth earpiece it
Start with your headset turned off. Then, press and hold the answer/end button, until the indicator light is steadily lit in blue. It is in paring mode now. Then, make the bluetooth application on the device you want to pair your headset with, search for new devices. After a while, the BT350 headset should appear in the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, if your headset's user manual happens to be missing, feel free to download it from this location.
Hope it works for you.
Regards, Carlos
Posted on Jul 10, 2010
Manual for jabra t820
To pair the Jabra with a Verizon Wireless phone, the phone must have Bluetooth. Bluetooth allows a device to communicate and transfer data with another Bluetooth device without having to be physically connected to it. The instructions for connecting the Jabra with the Verizon phone vary slightly depending upon your phone model. Jabra headset instructions don't vary per model.
Jun 19, 2012 | Radio Communications
I hav a jabra bluetooth....type ote3 and i lost my directions for connecting it to my phone. i hav a samsung gravity phone i went to settings under bluetooth and turned it on and searched for devices but...
1. Put the headset in pairing mode and make sure that the headset is on. To do this: Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra headset
(Follow your phone’s instruction guide to do this)
3. Once your phone locates the headset, it will ask you for a code to pair with it, the code for jabra headsets is usually 0000
Sep 02, 2010 | Cell Phones
How do i pair my jabra w/my phone. cant find
hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
Sep 07, 2009 | Jabra BT125 Headset
Can't connect
In your Jabra bluetooth headset, press and hold the button in the headset until you see BLUE flashing light. Once the light is flashing in the Jabra, go to your Motorola phone and search for any Bluetooth device in range. when the Jabra shows up, select the Jabra and put in the pin code for the headset "its either 0000 or 1234)
Cheers!
Jun 10, 2009 | Jabra Bluetooth Headset with Adjustable...
Cannot connect to my verizon env2 phone
Try this:
1) Charge the headset (plug it in until the LED light turns off. Didn't take very long for me) and unplug it...
2) Make sure the unit is ON (It blinks quickly when powering on and off, and blinks consistently while on, so it shouldn't be hard to tell) [the power switch is very slim and on the outer edge of the unit, labeled by a circle with a line in the middle]
3) Hold down the big silver button on the large outer flat surface of the unit until the LED light *STAYS ON* ***While that LED light remains solid, the unit is in Bluetooth "Discoverable" mode*** After you have put the hands free unit into this mode, then *promptly* follow your own cell phone's blue tooth pairing instructions, usually found in the "tools" or "settings" menu.
Apr 14, 2009 | Lands Phones
I lost my instructions to my Jabra bluetooth and can't remeber how to install on my chocolate phone by verizon
try holding down the "on" button on the jabra 'til you get a solid blue light that stays lit. Then go to connection/or bluetooth on your phone and follow the path to find or search for devices.
Regards,
Lonnie
Mar 31, 2008 | Jabra BT350 Bluetooth Headset Headset
Bought a Jabra BT135 and lost instructions to install, please help
1. ok when the headset is off keep your finger on the botton until it goes blue (stays blue)
2.when gone solid blue search on your phone for bluetooth
devices and you should find it
3. then it askes for the pairing key type in 0000
4.when you play music while bluetooth hedset is on and bluetooth is on it should play in the headset
Jan 22, 2008 | Cell Phones
how do I set up the phone to discover jabra vbt185z?
Dec 29, 2007 | Jabra BT350 Bluetooth Headset Headset
How to pair my Jabra BT125...
Instructions for the Jabra BT125 Bluetooth
For people who are having problems pairing their cell phone with their Jabra BR125 Bluetooth, here are a few simple steps:
First, make sure that the Jabra BT is off (the light should be off). If it's on, hold the flashing button until it goes off.
Second, turn your Jabra BT on. Continue holding your Jabra button (EVEN AFTER IT STARTS FLASHING). Hold onto it UNTIL YOU GET A SOLID LIGHT.
Third, as soon as you get a solid light try pairing up with your cell phone.
Fourth add your Jabra to your cell phone's Bluetooth list by having it search for the Jabra.
Fifth, the cell will ask for a passcode. The default passcode is 0000.
Aug 17, 2007 | Jabra BT125 Headset
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
4,830 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
