Question about Alpine Car Audio & Video
Unit error for usb port on alpine - Alpine Car Audio & Video
3 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Posted on Sep 23, 2009
  • 21 Answers
SOURCE: i have a problem on
MAKE SURE THE USB DRIVE IS FORMATTED IN FAT 32 -------- MY GUESS IS IT CANNOT READ FROM THE USB STICK
MAY NEED TO TAKE THE STICK BACK TO YOUR COMPUTER AND RIGHT CLICK ON THE DRIVE TO CHECK THIS ......... IF IT PLAYS ON THE COMPUTER TRY A REFORMAT ...
SAVE YOUR MUSIC ON PC FIRST --- THEN REFORMAT USB DRIVE CHOOSING FAT FORMAT ---- REINSTALL MUSIC ..........
Posted on Jun 29, 2011
Alpine ine-z928hd problem with software update
Be sure to format the memory stick using fat or fat32.
Apr 16, 2014 | Alpine INE-Z928HD - 8" In-Dash Navigation...
Usb device not recognized
It is a good possibility that the USB port is defective. You may try a different cable to see if it has the same results.
Jan 29, 2018 | Alpine Car Audio & Video
I have a problem on alpine Cd mp3 + usb player when i plug usb drive in usb port the Error-1 is showing on screen. please tell me the solution
Jun 29, 2011 | Alpine CDA-9885 CD Player
When I plug in my ipod into the the AIpine get an
Are you using the KCE-422i cable included with the unit? The iPod will not work plugged into the USB port with the factory Apple cable. You need to use the silly Alpine cable.
May 31, 2010 | Alpine IDA-X300 Car CD/ MP3 Player
My CDA-9886 usb error
I just got an A-male to A-female USB extension cable to hook up to the back of my Alpine CDA-9886 headunit and connect to my 32GB USB. All of the songs are MP3 and works with my brother's headunit. But when the USB is plugged into my headunit, it says error. How can I fix this?
Dec 25, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
Alpine - 50W x 4 In-Dash CD Deck Model: CDE-100 | SKU: 9438076 how do i opperate an ipod on it? do i have to create a playlist or something?
You have to run it through the aux input, the usb port will not play an ipod through it as it doesn't have the ipod 2.0 software on it, you can get a ipod connector that plugs into the back of the head unit, and then plugs into your ipod and you can control it from that as well as charge it, but other than that you have to use the aux input. The only thing you can play through the usb port is music on a thumb drive.
Dec 10, 2009 | Alpine Car Audio & Video
Hello desoren,
Hope this helps.
Sep 23, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Error 2 on usb reading
I have also been experiencing the very frustrating "Error Code 2" issue half way thru the calibration process. Sometimes the error occurs during measurement No. 1; other times on the 2nd or 3rd measurement.
I am running a MacBookPro running OSX 10.7 (Lion Server) w/ Vmware Fusion v4.1.1 and Windows XP (SP2).
After experiencing over a dozen of failed attempts to calibrate, I started to tweak the Windows setup.
I found out after some experimentation that the issue is not so much the Alpine Imprint S/W, but much so with the USB/Serial interface hardware. The S/W has issues with error recovery, which forces the user to close and restart the application if an exception is encountered...but if the exception can be avoided in the first hand, it runs fine!
Would suggest to try the following tweaks to address the Error Code 2 issue:
(1) If using Vmware Fusion, ensure that the USB/Serial is connected. On the VMWare Fusion menu, select Virtual Machine->USB & Bluetooth->Connect Future Devices USB<->Serial. Ensure this is connected first before launching the Alpine Imprint Sound Manger (v2.10) application;
(2) The USB cable that comes with the calibration kit is quite long and I am not sure the shielding is that good. So try to straighten the cable out and not allow it to coil when connecting to laptop; this should reduce any potential interference and signal degenerating issues;
(3) Within XP, open up Control Panel->Administrative Tools->Computer Management->Device Manager, locate under "Ports" the corresponding port that the USB<->Serial interface emulates. Usually this is USB Serial Port (COM3).
Open up the Port Settings under its properties menu.Apply the following override settings:
Bits per second = 921,600 (or 115,200 is fine as well)Parity=EvenFlow Control=Hardware
Click "Advanced" button and override the following settings:Minimum Read Timeout (msec) = 10,000Minimum Write Timeou (msec) = 10,000
These simple override setting works like magic for me.I was able to complete all the 6 measures without a glitch.Hope this works for your setup as well.
PS. For subwoofer calibration I also found useful tuning down the gain beforehand on the amplifier. On the Alpine head unit, set the Subwoofer output level to very low (close to zero). On the amp-side (I am using 3 x Pioneer PRS-D4200F) set the gain switch anti-clockwise to a voltage slightly above 2V (do not over do this). Then after the calibration has completed, set it to just below 2V (clockwise rotation) to slightly elevate the output. The remaining subwoofer gain adjustment can now be done comfortably from the head unit's subwoofer output control.
Cheers,Damo
Jun 14, 2009 | Car Audio & Video
Aipine ida x 100,usb device error
Are you using the original Alpine iPod USB cable? If not, that could be the problem. The iDA-X100 will only read iPods using the Alpine cable. Otherwise, you get a "USB Device Error."
Mar 08, 2009 | Alpine iDA-X100 Car CD/ MP3 Player
Car Audio & Video Logo
35 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
