Question about Samsung Sprint Airave Wireless Access Point SCS-26UC2
Scs-26uc2 reset reset the unit
How do i set up netflix on the LG BP340 blu-ray player
NETFLIX- CANNOT STREAM TITLES
Streaming difficulties are often the result of a low network connection speed. If you experience poor quality video, or videos have to stop and buffer frequently then the bandwidth of the home network may be insufficient. Network ready televisions will scan the available bandwidth and adjust the quality of the video so that it is presented without interruption.
[img alt="" align="middle" src="http://faq.scs.lge.com/common/FileDownload.do?fileId=BD_N-1335350824562" width="710" height="9"> Does this happen with all titles or only one? If this occurs with only one title, the stream could temporarily be down or experiencing an issue and will need to be reported to Netflix.
If this happens with all titles, check your network settings first.
Unplug the power cable to both the modem and the router for 15-20 seconds.
Connect the power cable back to the modem, then the router.
The modem must be connected first unless you are using a router/modem combo unit.
If the problem continues after the network reset, perform the steps below.
Press the Home/Menu/Setup button on the LG remote.
Choose Setup.
Select Network.
Access Netflix.
Select Netflix Deactivation.To reactivate Netflix you will simply log back into your Netflix account.
Jul 29, 2014 | LG BRay Disc Player With BuiIn Wi-Fi -...
How do I connect a Stanton SCS.4DJ turntable to my pc
This is a simple to use unit. Just plug the "line out" of the turntable to your "line in" on your PC or laptop. This is to just straight up record what you're mixing or playing as an audio file.
Jul 12, 2014 | Stanton SCS.4DJ Mixer Console
Password reset
just do it with the help of settings option
May 13, 2013 | Lexmark 19Z0031 X860de/X862de/X864de For...
How to set a scs sailing watch
For scs watch details,click the link below :---------http://repairhelpcenter.blogspot.com/2012/01/scs-sailing-watch-details.html
----------Thanks.
Jan 14, 2012 | Watches
Srs light stays on on my Honda civic
The most likely possibility is the connector for the airbag is not on securely. Check the connector first. But if the connector is connected properly then you will have to get the error codes to locate the exact problem for SRS light ON.
There is a way to pull the codes from the SRS control unit without a scan tool.
1. Turn the ignition switch OFF , and wait for ten seconds. Then connect the SCS service connector to the service check connector (2P). If you do not wait ten seconds, the SRS unit will not be completely reset and will not output DTCs.
2. Turn the ignition switch ON (II). The SRS indicator light comes on for about six seconds and goes off. Then it will indicate the DTC:
· The DTC consists of a main code and a sub-code.
· Including the most recent problem, up to three different malfunctions can be indicated.
· In case of a continuous failure, the DTC will be indicated repeatedly.
· In case of an intermittent failure, the SRS indicator light will indicate the DTC one time, and then it will stay on.
· If both a continuous and an intermittent failure occur, both DTCs will be indicated as continuous failures.
· In case the system is normal (no DTC), the SRS indicator light will stay on.
3. Read the DTC.
4. Turn the ignition switch OFF, and wait for ten seconds. Then disconnect the SCS service connector from the service check connector (2P).
The SCS Service Tool is nothing more than a jumper wire.
Thanks. you can rate this solution and show your appreciation.
May 19, 2010 | 2000 Honda Civic
Battery was low and put in new battery,problem SRC Light stays on how can I reset the SRC light?
I'm guessing you mean the SRS light, yes. When you have a bad battery the battery voltage can drop below 10 volts. The SRS unit detects this voltage loss and set a DTC (diagnostic trouble code) for an internal SRS unit failure. You have to erase the DTC memory. You'll need an SCS service connector tool (P/N 07PAZ-0010100) You can order one from your local honda dealer. Don't worry its not more than $10. Then you'll have to find the MES 2pin connector located in the upper right hand corner of the drivers underdash fuse box. It can be gray, green or yellow in color. 1.)Turn the ignition switch off. 2.)Unplug the MES connector from the fuse box and plug your SCS special tool into the MES connector. 3.) Turn the ignition switch on. 4.) The (red) SRS light in the dash will come on for 6 seconds and then go off. Remove the SCS tool from the MES (2P) connector within 4 sec. after the SRS light went off. 5.) The SRS light comes on again. Reconnect the SCS tool to the MES (2P) connector within 4 seconds after the SRS light came on. 6.) The SRS light goes off. Remove the SCS tool from the MES (2P) connector within 4 sec. 7.) The SRS light indicates that the memory is erased by blinking twice. 8.) Turn the ignition switch off and wait ten seconds. You may have to do this procedure a few time to get the steps correct. If this sounds to complicated I'm sure your local Honda dealer would be happy to reset the light for you for no charge. Just let them know that the battery was recently replaced and you think that the SRS light came on due to low battery voltage. -Hope this helps:)
Jan 13, 2010 | 1997 Honda Civic
How to restore to factory default settings ricoh
enter service mode then execute these service programs I would do an sp print
5990- 2 out first just in case
5801 Memory Clear
Resets software counters and returns modes and settings to their defaults.
All clear: Clears all data
Engine clear: Clears the printer engine settings
SCS: Clears the systems settings
PRT: Clears user mode system settings
NCS: Network control systems - Clears the items listed in the “Host Interface”
section of the Configuration page.
DCS: Delivery control system (e-mail settings)
MIRS: E-mail addresses
5801 1 Memory all clear
5801 2 Engine memory clear
Resets the following user tool settings:
Maintenance menu: Main scan registration, sub scan registration, image
density, curl control
Resets the settings of the following SPs: 1003, 1104, 1105, 1902, 1910, 2001,
2112, 2113, 2201, 2213, 2301, 2910, 3921, 3922, 3923, 3924, 5930
5801 3 SCS memory clear
Paper Input menu: Paper type, paper size, tray lock,
System menu: Energy saver timer
Resets the settings of the following SPs: 5009, 5812
Also resets the user code counters.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
Srs light on
1st you need to either buy or make the "SCS Service Connector" #07PAZ-0010100 from H and A Accesories for $3.51. Use a speaker harness for an older Honda which you can buy at a local stereo shop such as Circuit City or Best Buy, and cut the wires and looped them together. You can also use a paperclip but that will make it a little more difficult because you have to connect it and disconnect it a few times quickly. 2nd you need to find the MES (Memory Erase Signal) connector as pictured below scs_small.jpgsrs_plug_small.jpg
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug.
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
Aug 16, 2009 | 2002 Honda Civic
Jam
SC555 is a fuser error there are a few possabilities that could have caused this..
1 You have a peice of paper trapped in the fuser unit(the heated rollers)
2 The fuser unit is not fully home
3 The thermistor/fuser lamp has a malfunction
Fusing unit SCs displayed on the operation
panel. The machine is disabled. The user
cannot reset the SC.
Turn the main power switch off
then on before entering SP mode.
Reset the SC (push "EXECUTE"
with SP5-810), then turn the main off then on again
Jun 26, 2008 | Ricoh Office Equipment & Supplies
Samsung Sprint Airave Wireless Access Point SCS-26UC2 Logo
37 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
