Question about Acer Aspire E380 ASE380-UD500A PC Desktop
Kernal Memory dump, why does this continue occurring?
For no apparent reason my pc will cease working and freeze and the kernal memory dump message follows. Why does this occur and what can I do to prevent this from happening. I would just like to be able to use my computer without it shutting down then having to go through launch repair. I changed the ram and the motherboard.
    Sergeant:
  • 238 Answers
This is a software problem. In order to get a better answer, you really should supply at least the following information: make and model of computer and operating system. For some general fixes, these are what I suggest.
1. Run the system file checker:
Start>run, type in sfc /scannow<enter>
You will need the OS disk in the drive for this.
2. Run Windows Update.
3.Update all your drivers, especially your video driver. If you're not sure what is in your system, get the free Belarc Advisor at http://www.belarc.com
4. Check the vendor's sites for updates to all installed applications.
Posted on Jan 23, 2009
    Problem Solver:
  • 35 Answers
Log into safe mode and go to the Control panal. then go to "administrator tools" then go to "Event Viewer" then on the left hand side look for the menu "Application" and to the right look for Red X and read what is says. go vist www.eventid.net and type in the code.
i know you know this but something is wrong with your OS. you can try repair install or format reload. also any devices or solfwware could be confiliting with it. ex. new printer, digital cam....etc...
What is reentrant kernal?
It is somewhat complicated to explain. The basics of it is it is what allows processes through the CPU. If you are getting a kernal. error, they mainly share the memory and can become corrupt when they attempt to run at once, not in an organized manner. Hopefully this helps you out somewhat.. if you have any other questions let me know and I will attempt to break it down in more depth.
Oct 23, 2010 | Computers & Internet
My PowerPC keeps shutting down unexpectedly, any time it wishes, most annoying. Screen turns grey from top down then message appears telling me to reboot, Mac has shut down unexpectedly. Messages refer...
Sometimes this can be caused with memory problems Reseat the memory by switching off the G5 then take out the memory and replace it back. It could be that it is slightly loose. Hope this helps.
May 23, 2010 | Apple Power Mac G5 Desktop
Whenever i go into R4i-sdhc it says 'System date error! Please check NDS system date'
For some reason it does not like 14th April date, we set the date on my daughters dsi back to the beginning of April and it work fine now. Hope this helps
Apr 18, 2010 | Nintendo DS Lite Console
A blue screen pops up something about a crash dump
sounds liek you installed some hardware the pc did not like. plossibly memory that is not supported or video card that is not supported (some thing that a core item to the pc operation).
If this is not the case, one of these core items is faulty it sounds like. Another possibility might be some corrupted software like the OK throwing up kernal errors (blue screens). I would try to boot in safe mode to see if it happens there. If so, you will either have a hardware issue or OS one.. try the repair installation to see if it helps any. after that is looks like some hardware swapping.. hope that helps
Stan Skaggs
Nov 24, 2009 | Compaq Computers & Internet
A blue screen came up saying something about the memory module!
oh k..
so u mean whenever u start ur computer or whenever u work on it, it shows Blue screen...
This blue screen is called BSOD Error (Blue Screen Of Death)
It occurs due to several reasons but since u specified abt memory, this might be showing you Kernal Memory Dump, i hope..
Dont need to panic, try to start up computer in safe mode & restore it to previous known date at which u didn't had that problem..
It generally occurs after installing some new softwares or drivers that conflicts with the memory module.. so try to restore ur system else try removing ur newly installed software or driver...
Hope this helped u out..
Thanks....
Aug 27, 2009 | Toshiba Satellite A65-S1062 Notebook
Screen freezes,then a brown looking film comes on
this is a kernal crash, try starting with the left shift key depressed, this does a bunch of "housework" and is safe boot. Have you fitted any memory or anything lately? . You could also give the disc utility on the system disc a go, verify the hard drive and then repair the permissions, It could be a sign the memory or hard drive is failing, a bad sector on the hard drive can be sorted by re instelling the system software
Jul 22, 2009 | Microsoft Zune JS8-00001 Digital Media...
My lg phone says it needs a puk code to work again
You probably already tried the retail dealer...so if the code is un found, there is a kernal memory dump error..and sadly your phone is un recoverably..try the manufacturer or get a replacement...
Jun 16, 2009 | LG Shine KE970 Cellular Phone
Kernal panic
To reset nvram,
Press "cmd alt O F" at startup
Then enter:
reset_nvram (press enter)
reset_all (press enter)
A kernel panic can come from a lot of things (peripherals, corrupted file, or damaged hard drive or memory). The best is to check in the log file what caused the kernel panic, or to proceed step by step, checking one thing after the other, until the problem is resolved.
May 30, 2009 | Quicksilver Computers & Internet
Kernel library refuse 2 load after booting touchpad,keyboard frez
can you do a windows update
for some reason the kernal library has been removed
and if that does'nt help can you do a system restore
Jan 18, 2009 | Computers & Internet
Acer Aspire  E380 ASE380-UD500A PC Desktop Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
