Rank: Master
Rating: 74%, 36 votes
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker.
You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!)
[NOTE: Your unit has an internal overload protection system to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized service center must do this.]
But, before you take it in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious!
If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it.
Hopefully one of these "fixes" will work for you. GOOD LUCK!
Comments:
Jul 18, 2007
- WHAT HAPPENS WHEN YOU DISCONNECT ALL OF YOUR SPEAKERS, T H E N TURN THE POWER ON?
