Question about GE GSS20IEM Side by Side Refrigerator
Reset the derost timer ge gss201emd ww - GE GSS20IEM Side by Side Refrigerator
3 Suggested Answers
  • 1218 Answers
SOURCE: where is the defrost timer on a GE model gss20iemb
Good day,
Doesn't have one. It functions thru a motherboard mounted on the bottom back rear of the machine.
Normally 5 thermistors are used (3 in the freezer 2 in the fresh food compartment) to operate the machine.
Defrosting cycles are controlled by the motherboard with the input as well from compressor running time and the number of door openings.
Posted on May 01, 2010
kel1guy2002
  • 3740 Answers
SOURCE: ge gss201emd ww not freezing
The real problem here is that the ice you see on the back wall is blocking air flow so the unit can not get cold. The ice block is caused most of the time by a problem with the automatic defrost circuit.
Since you omitted the last few digits of the model number I will cite this model as a reference:
GSS20IEMDWW
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100553&diagram_id=22357929#d22357929
Components that can cause defrost problems are:
Items 230 (Defrost heater), 240 (Defrost themost), and 241 (Temp sensor) of the above link.
or....
The main control board assembly Item 801 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100553&diagram_id=22357925#d22357925
And internal wiring if there is connector or chaffing problem.
To get rid of the ice for 2 - 3 days you can do a MANUAL defrost by unplugging the unit and removing the freezer contents. Then direct and external fan into the unit for just over 2 hours ro melt all of the ice while it makes a water mess that will need tended to. After the 2 hours return the unit to normal use. If the ice block / rear panel frost returns in 2 - 4 days you have an automatic defrost problem that will need service. Until the defrost problem is corrected you can plan on doing manual defrosting sessions as directed above in 3 - 4 day intervals.
Thanks for choosing FixYa,
Kelly
Posted on Jul 07, 2011
Where is the defrost timer located on model GE GSS22JETG WW? This is a side by side
USUALLY LOCATED IN THE FRIDGE AT MIDDLE TOP BUT SOMETIMES CAN BE FOUND IN THE FREEZER ALONG THE WALL
Mar 08, 2015 | GE Refrigerators
GTS18DCPRRBB
need derost timer wiring diagram
Feb 18, 2014 | GE Refrigerators
Where is defrost timer on model DSS25JFPA WW
IT DOES NOT HAVE A DEFROST TIMER EVERYTHING ON THIS UNIT RUNS OFF A MAIN BOARD
Jan 16, 2013 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
How to locate and replace defrost timer on GE GSS23KGSA WW
Yes the GSS23KGSAWW defrost is controlled by the WR55X10942
motherboard. What is happening that you would ask about a defrost timer? Let me know if you have questions, Thanks Sea Breeze
GSS23KGSAWW Service Manual
Nov 19, 2012 | GE GSS23KGS Side by Side Refrigerator
GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigerator(GSS22ifrf ww) not cooling
Try unplugging it for 30 seconds and then plug it in again. It may reset itself that way.
Jul 29, 2009 | Refrigerators
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Coils ice up
appears to be the defrost timer,unit should have advanced out of defrost within the time you listed
Jul 17, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Microwave won't work; timer word stuck on screen
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Our site is linked here on Fixya: http://tinyurl.com/yzjozk
Oct 25, 2007 | GE JVM1340AW/BW/WW Microwave Oven
GE GSS20IEM Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
