Question about Crosley CAE12ESR Air Conditioner
How to reset filter reset light - Crosley CAE12ESR Air Conditioner
After replacing filter, how long before filter light goes off?
Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
The above is how to reset the indicator
Jan 22, 2016 | Samsung RF4267HARS 27 cu.ft. French Door...
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
How do i reset the waterfilter light
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
If you have other questions please let me know, Thanks Sea Breeze
Jun 10, 2011 | Jenn-Air JCD2389G Side by Side...
Have replaced the water filter - how do i reset/turn off the "change filter" light ?
Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • May 18, 2010 | Maytag MZD2766GES Side by Side...
    Reset water filter light
    (Select Models)
    FILTER
    operate if the filter bypass is in place. Let me know if you need the complete manual, Thanks, Sea Breeze
    Apr 16, 2010 | Maytag MZD2766GES Side by Side...
    Reset filter light
    (Select Models)
    FILTER
    If you want complete service manual please let me know, Oh Please rate Me, Thanks, Sea Breeze
    Apr 09, 2010 | Jenn-Air JCD2389G Side by Side...
    Change filter light
    Water Filter Status Indicator
    Light (select models)
    The Water Filter Status Indicator Light serves as a
    reminder to replace the water filter. A green light
    indicates that the filter is in good condition. A red light
    indicates the filter should be changed. Once light turns
    red, it will remain red until function is reset.
    To Reset Indicator:
    • Press and hold both the Lock and Water
    buttons simultaneously for four seconds. The
    green filter status indicator light will flash
    three times when the function has
    successfully reset.
    Sea Breeze
    Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
    Changing light after installing new water filter
    (select models)
    To Reset Indicator:
    • Press and hold both the LOCK and WATER
    successfully reset.
    Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
    The warning light to reset filter came on. I've
    Resetting your Refrigerator filter indicator light after changing your water filter Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
    Step 1:
    Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
    Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
    Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
    GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
    HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
    Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
    Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
    Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
    Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
    Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
    Step 2:
    Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
    Once these two steps are completed, you are all set to enjoy great tasting ice and water through your refrigerator. If you don't see your manufacturer listed or the insructions don't work for your model please post a comment with your make and model number so that we can provide exact instructions for your model.
    May 06, 2009 | GE PDS22LBN Bottom Freezer French Door...
    How do you reset the change filter light , have replaced filter
    Question:
    I have replaced filter but how do you reset change filter light?
    Have replaced the filter. The light is still red. Answer: After changing the water filter, press Cubed and Crushed buttons simultaneously and hold 3 seconds.
    Jan 28, 2009 | Samsung RM255LASH Side by Side...
    Crosley CAE12ESR Air Conditioner Logo
    23 people viewed this question
    Top Crosley Heating & Cooling Experts
    David White
    J Rosado
    Kiri Amarakoon
    Are you a Crosley Heating and Cooling Expert? Answer questions, earn points and help others
