Question about Royal Heating & Cooling
Parts for royal sovereign CO-2000 coin sorter
Need replacement tubes
3 Suggested Answers
  • 148 Answers
SOURCE: Royal Sovereign not keeping the room cool.
electronics give off alot of heat you need larger unit
Posted on May 19, 2009
SOURCE: i need to find the replacement parts for the
Here is the solution to all parts! :)
http://www.searspartsdirect.com/partsdirect/part-model/royal-sovereign-parts/room-air-conditioner-parts/Model-ARP1000ES/3229/0904032/50028633/00001
Posted on Jul 05, 2011
How do I fix the water leaking problem with my royal sovereign 1008 a/c?
that depends on where it is leaking from , as leaking is one of the things air conditioners do . since they act as dehumidifiers also . some have drain tubes some just need tilted so water runs outside.
Jul 20, 2015 | Royal Sovereign Heating & Cooling
FS-4DA coin sorter won't count pennies
The good news is that the unit is functioning, it's just counting pennies. I had the same problem with quarters and is a fairly easy fix. I won't get into any disassembly details, but you'll need to gain access to the infrared detectors (mounted to the motor assembly) and possibly the emitters (mounted to the front panel LCD display/push button board). Also, please be careful not the damage the wire harnesses when removing the top cover. Once apart, you can use your cell phone camera (which is sensitive to infrared) to see a purplish/white glow from a healthy emitter. Compare the penny emitter to the others and chances are it will have a lower output level and need replacing. If the penny emitter is strong, then check the detector with any infrared remote control( TV, cable box...) by pointing the IR remote control towards the penny detector and pushing any of its control buttons. This should make the penny amount count up, and fast too, as the remote sends out IR pulses while a button is being pushed. If this test doesn't increment the penny count, then the penny detector needs replacing. But before you do, try this remote control test on another known good detector to verify your findings. Please keep in mind that other malfunctions besides an emitter and detector could be the cause of your problem, but given the FS-4DA circuitry, the odds are extremely high that you have a bad emitter 1st, then a detector 2nd, as emitters are known to degrade over time and especially when continuously powered, as in the case of a switched 'ON' FS-4DA. FYI...IR emitters and detectors can be purchased from Radio Shack. Good luck and take care not to electrocute yourself when powering the unit with its cover removed.
Feb 21, 2014 | Royal Sovereign Fs 4DA Model Fs 4DA Coin...
May 19, 2009 | Royal Sovereign ARP-4009 Portable Air...
Heating & Cooling Logo
Top Royal Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Royal Heating and Cooling Expert? Answer questions, earn points and help others
