Question about Kenmore 22422 Top Load Washer
Leaking water after spin
It appears the tub spins out of line with the fill stream, suspect a stopper that should prevent this is worn or broken allowing the tub to move beyond its set point. Wanted to check before pulling the washer apart.
  • cybrus77 Jan 23, 2009
    Model Number is incorrect should be 4121092 thanks,
    cybrus77
    Sergeant:
  • 311 Answers
The most common issue i have had with your problem is a spring wears threw the hole made for it .if so drill a new hole next to old you can even bend the end of the spring tab in a pinch.but if its broken you should purchase new spring.to look at your washer innards,[this is for most models some have sound damping material at the bottom]pull your washer away from the wall and tilt back ,then you can see underneath.the spring im speaking of is in the back.left,middle.its running vertical from the tub frame to the washer frame.there are other possibles but that's the most common.if you need more help please feel free to email thew fixya web site God bless, tom
Posted on Jan 23, 2009
Drum not spinning or draining. Making a sound like something is trying to run but cant.
Check the power. If your Kenmore washing machine does not operate at all, you may need to replace defective or blown fuses or reset a tripped circuit breaker. This is done by moving the lever to the "Off" position and back to "On."
  • Examine the lid switch to see if it is defective. A malfunctioning switch can prevent the machine from operating or spinning. The switch can be found on the inside close to the door frame. Some models also have a special "lid-switch" fuse close by the lid switch within the control panel. A blown fuse will not allow the washer to fill with water.
  • Unclog the drain line if the machine is spinning but not pumping out water. If the problem still isn't fixed, the pump may need replacing.
  • Look for a broken pump belt or frozen water pump pulley if the machine does not spin or pump water. Test the pulley by disengaging it from the appliance and physically turning it. It should rotate freely.
  • Determine if the motor coupler or belts are broken, which could prevent the washer from spinning. Failure to spin also could be the result of a worn clutch, a malfunctioning drive motor, an improperly shifting transmission or a worn or "seized" spin bearing or basket drive. These problems also could keep a washing machine from agitating.
  • Find the source of a leak by checking the washer's air gap, inlet spout and rubber tube. Replace any items that are cracked, worn, deformed or disengaged.
  • Test the motor coupler, water-inlet valves and the drain hoses if your clothes are wet following the spin cycle. Replace these parts as needed.
  • Hope this might help u out!
  • Nov 08, 2010 | Kenmore Washing Machines
    I have a GE model WHDRE526E1WW washmachine.The complaint was it would not spin. I checked the agitator coupler and the washmachine agitates but won't spin or fill with water. I suspect it may be the...
    Try suspecting the tub end of the water level tube being plugged with " goop " so that the washer thinks it is still full of water, thus will not fill or spin. Take the front panel off by releasing the push in clips at the top of the front panel, in the seam where it meets the washer's top. Now, find the tube at the left side of the outer tub and pull it off the tub. Clean it out or cut off an inch (don't do the cutting thing more than one time) and replace after using a thin wire to clean out the tub end of the attachment. To help prevent this from re-occuering, every few months, fill the washer to the lowest setting with the hottest water, no clothes, and several cups of bleach, and run the longest cycle you have (with no clothes, of course). Make sure to rinse out the tub on a higher water level before you wash a load of clothes.
    Sep 06, 2009 | Washing Machines
    Water is running out inside bottom of mechine
    If the washer leaks only during the fill cycle, check these:
    1. Air gap device: It is a small device found on most washers to prevent the wash water from from being siphoned into the household water supply. It is located either midway along or at the the end of the black rubber hose that comes from the water inlet valve It is usually made of a translucent plastic. If it is deformed or cracked, you need to replace it.
    2. The tube: It is a rubber tube that runs between the water inlet valve and either the air-gap or the inlet spout. If it is broken, it can cause a leak.
    3. Inlet spout: Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If broken or loose, it can cause a leak.
    During the drain and spin only:
    1. A washer that leaks only during the spin cycle often has a leak in the main drain hose. Check the entire hose and correct any problem you can find.
    All the time:
    1. Hot and cold water fill hoses: Check the hot and cold hoses from the household plumbing. If either hose is leaking, tighten or replace it.
    2. Main tub seal: It is located between the transmission and the outer tub. Open the the machine's main access panel while the machine is full of water with a small amount of detergent. The leak appears at the underside of the outer tub, at or near the center.
    3. Pump: You can probably see the leak when the tub is full of water. If it leaks, replace it.
    4. Outer tub: Steel or plastic outer tubs can rust, split or be punctured. Consult a qualified appliance technician if it is the culprit.
    Aug 22, 2009 | Speed Queen Washing Machines
    Leak during rinse and final spin
    Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
    During fill only
    During drain and spin only
    All the time
    During fill only If the washer leaks only during the fill cycle, check these:
    • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
    • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
    • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
    During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
    All the time If the washer leaks all the time, check these:
    • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
    • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
    • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
    • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
    May 20, 2009 | Washing Machines
    Noisey during spin
    yes you are right noise during spin cycle is due to faulty bearing. If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
    Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
    Pictures of this job...
    A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
    Picture1 - Picture2
    The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
    Picture1 - Picture2 - Picture3
    I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
    Picture1 ( boot pushed inside ) Help page1 - Help page2
    It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
    During fill only
    All the time
    May 07, 2009 | LG WD-16115FD Front Load Washer
    I have Frigidaire front loading. During the spin
    During fill only
    All the time
    Apr 03, 2009 | Frigidaire Washing Machines
    Leaking washing machine
    It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
    During fill only
    All the time
    During fill only
    All the time
    Nov 02, 2008 | Frigidaire FGX831CS Top Load Stacked...
    My front loader is leaking water from the bottom
    During fill only
    All the time
    During fill only
    All the time
    Oct 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
    My washing machine wont spin and it leaks water
    If it does not spin see the following suggestions from Repairclinic:
    " It doesn't spin If your washer won't spin, check these:
    It doesn't pump or spin
    It pumps, but doesn't spin
    It spins only with the lid closed
    It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
    • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
    • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
    • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
    • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
    • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
    • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    On leaks:
    During fill only
    All the time
    Sep 03, 2008 | Washing Machines
    Water leak under machine not the hot cold water lines
    During fill only
    All the time
    Jul 12, 2008 | Hoover Washing Machines
    Kenmore 22422 Top Load Washer Logo
    47 people viewed this question
    Sal De GO PATS
    fordexpert
    Ed Mac
