Question about Sony KV-27V10 27" TV
SONY Trinitron color television Parts | Model KV-27V10 ...
Eriez
  • 14 Answers
SOURCE: Sony trinitron KV-X252 1D
Hi Franciscus,
Is your TV newly purchased ? When you bought that , had you ask the manuals, I do believe every units must have, no matter what brand or model it will be, CE required that act. So ask to your distributor or the store where you bought it unless , it has been passed from one owner to owner, or you bought this from somebody at lower price,,,,perhaps, maybe...but where is the manual? So I hope this reminder will help you... Pls. send feedback...thanks
brgrds,
Eriez
Posted on Apr 05, 2008
  • 4234 Answers
SOURCE: Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Posted on Jul 14, 2008
ikecur
  • 52 Answers
SOURCE: Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Posted on Oct 30, 2008
SOURCE: no sound (sony trinitron kv-2197pf 21" tv)
try to short the spider transistor along ic amplifier. it is in a mute
Posted on Nov 12, 2008
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Sony KV-27V10 Lound Buzzin When Screen Full Or Bright
Check for any faulty electrolytic capacitors in the main power supply regulator section.
Dec 22, 2012 | Sony KV-27V10 27" TV
Sony Trinitron KV-27V10, power supply getting power to first relay, power button has continuity, how do I get power to power button ?
first check for power supply operation..maybe a defective horizontal stage might caused this type of defects
Jul 15, 2011 | Sony KV-27V10 27" TV
My model is sony trinitron KV-HW212M53. now the color of sreen display is so bad, some time green, how to solve this problem?
Standard CRT(tube tv) have a video board,that the board is connect to the CRT tube pins neck to get a picture.That board have dead parts or cold solders parts on it to cause this problems.
Oct 23, 2010 | Sony Televison & Video
KV-X2971D Missing Manual
Go to
http://www.justmanuals.com/sony-trinitron-color-kvx2871a-kvx2971d-kvx2971d-kvx2972u-kvx2871k-kvx2973e-chassis-ae2b-parts-service-pi-43354.html?osCsid=pvqp39f41ricf7rkltucmagbo7
Jun 28, 2010 | Sony Televison & Video
Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
May 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Intec G8621 Wireless Remote Control For Xbox 360 - Need Codes
Does any one know the code for the PHILIPS model 40PFL7505D/F7 HD
Mar 08, 2009 | Sony KV-32FS13 TV
Sony kv27 s42 trinitron color tv
your tv has a problem inside..the supply that is going to the tube was been cut out... only the servicemen can do fixing your tv... there is a deefective parts...
Sep 18, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
For Sony KV-1415WR problem
Hiii...
First :
what chassis your tv set have ?
#2 : Where exactly the location of D608 ?
#3 : How may time the LED Blinking ? like we all know Sony have selft diagnostic with it ?!
I hope hear from you soon...
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Oct 08, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
