Question about Honeywell Programmable Thermostat Heater
ERROR CODE 90 HONEYWELL - Honeywell Programmable Thermostat Heater
Filter light is on Honeywell thermostat and I replaced
Your filter change reminder is based on time. The tstat has no way of knowing how dirty the filter us. 30 days, 60 days, 90 etc. You have to enter the configuration menu and do away with the "filter change reminder." Honeywell makes 400 tstats, if you don't have the manual we need model number!
Jul 11, 2017 | Honeywell Heating & Cooling
What does the code Lng/Rng mean on my Honeywell alarm panel box mean?
back up dialer (cellular, wireless) trouble. look for code after that display to see if what the error is
Dec 09, 2016 | Honeywell Home Security
Why is it showing error code 90?
Sounds like a all the bells and whistles thermostat, why did you chose that one?
090 Data interface is continuously busy.
A log of error codes can be viewed at the end of the installer setup after the system tests. Active errors will be shown first. The Error Log will log the last ten errors (active and inactive).
Pressing the reset button will clear all inactive errors from the
error log; active errors can not be cleared until the condition has been remedially busy
Dec 27, 2015 | Honeywell TH9421C1004 VisionPRO IAQ Total...
Honeywell 17KW generator error code 1100
You most likely have a fuel problem. Either not enough or too much pressure. What fuel are you using, propane or natural gas?
Dec 07, 2014 | Honeywell Electrical Supplies
Where can I find a list of error codes on the Honeywell 6160?
http://www.security.honeywell.com/documents/vista15p_20pUM.pdf
Jul 30, 2014 | Honeywell Ademco 6160 Alpha Keypad Vista...
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Jul 18, 2011 | Water Heaters
Have a honeywell thermostat t6575b1003 and my a/c unit wont get below 90, is this a thermostat issue?
Does it feel like 90 where the thermostat is located? If it's not hot in that location, then your thermostat is most likely going bad as far as the temp. goes. If the A/C isn't cutting off, then the thermostat doesn't know what the temp is to cut off. I would suggest replacing it if you have these symptoms. If it feels 90, you need to have the unit A/C unit checked out.
Jun 13, 2011 | Honeywell Heat/Cool Thermostat
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
74 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
