Question about Bosch Ovens
Wiring diagram for hbn13m250b/03
Trips house circuit breaker on selection of temperature control
5 Suggested Answers
SOURCE: My Kenmore Continuous Cleaning oven is older - it
If you are tripping a 50 A breaker, you have major problems. First check the breaker, to make sure it is in reality, tripping at 50 amps. As they get older they can suffer heat damage, and will trip at lower currents. How old is it? Does it visibly look like bad (burnt, etc) Is it loose on the mounting buss? Burnt smell? If everything checks out then go to the oven and look for loose connections. There will be heat where there is a 50 amp current draw. If the oven is suspect, I would seriously consider dumping it as soon as possible. This is serious fire safety hazard. Again, loose connections. Check all of them, both AC+ legs, Neutral, and ground.
KF Groves
Posted on Jul 18, 2009
barkencoa
  • 3463 Answers
SOURCE: DeLonghi EOF260 tripping the circuit breaker
It is probably an element that is causing the trouble, as it gets hotter, the insulation resistance breaks down, and if there is a weak spot or hot spot it causes the trip to operate.
I'm afraid it is a question of elmination, trying different functions, until you isolate the problem.
Posted on Feb 09, 2010
  • 3247 Answers
SOURCE: Just bought a house that has the JTP56 Double Wall
You have to be aware that the self -clean function whilst very convenient, tends to heat up the oven tremendously. Depending on the age of the oven it can be detrimental to it.
I am assuming in your case the lower oven has suffered some damage due to the heat generated during self clean. Generally the first one to suffer is the heat sensor or the heater. If the circuit breaker is tripping then the heater may have fused or the wires feeding the lower oven are shorting due to insulation breakdown.
Not sure how much comfortable you are with electrical repairs. May have to test out a few things before deciding whether to buy the components yourself and fix or get someone to do it.
You can checkout the location and description of the parts in these diagrams. Please turn the mains power off before attempting anything.
Please rate this solution if you find it useful else post a comment. Please note that if other fixya consultants have given you some suggestion then I cannot see this at this stage. cmmiuser01.
Posted on Oct 15, 2010
seddy29732
  • 147 Answers
SOURCE: Electrolux EOB 6632 oven trips
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
Posted on May 05, 2011
Oven doesn't seem to work though te light goes on
Check your circuit breaker for the house. It will be 2 breakers side by side with their handles pinned together. If one trips, but not the other then you'll get 110 volts to work the light and the control panel but not 220 volts for the element.
May 15, 2017 | Ovens
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 | Ovens
I have changed oven switch plus new elements and still oven does not work pls assist thks
Oven temperature will be controlled by a thermostat which might be separate from the oven switch. There possibly is also a thermal fuse or breaker to protect against serious overheating in the case of thermostat failure.
One of those devices or the wiring or connections is probably faulty and continuity should be checked through the circuit with an appropriate meter.
Feb 03, 2016 | Ovens
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Baumattic Bt2760ss oven trips power
Check fan to see that it spins freely. Look for any evidence of rodent nests or damage( chewed wires ) check breakers and wiring to make sure they are properly sized for the oven. Hope this helps.
Jan 18, 2014 | Ovens
Broil trips circuit breaker every time
I would start by replacing the breaker. They do become weak over time.
Dec 05, 2012 | GE JRP28 Electric Double Oven
I was gettin a F5 error andnow i get a F3 error
These are both problems with you Temperature sensor and circuit.
I would check the sensor first. You should have close to 1100 ohms. If this checks out good and wiring looks good the relay is integrated into the board so you would need to replace the control. The info below was taken from www.appliancehelponline.com You can also find diagrams there to show you what these parts look like.
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control.
· Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
F5
Relay safety circuit failure
· Check oven temperature sensor circuit for intermittent high resistance.
· Check lock circuit
· Press Clear/Off and reprogram control. If code reappears, replace control
Note: If all above check OK the F5 code can be a result of a momentary loss of power (Do NOT replace control or lock, check lock circuit)
Mar 21, 2010 | GE JTP15 Electric Single Oven
What is blue wire on ge built in oven for
The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
Sep 07, 2009 | GE Profile 30" Built-In Single Electric...
Ovens Logo
21 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
