Question about Pool & Spa
Heilsa pellet stove model qcps-28000 Fan exhaust is broken. Need to know how to change it.
There is a rattle in the fan exhaust. Need to fix it or replace it. Need to know how.
3 Suggested Answers
SOURCE: 5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
Posted on Feb 07, 2010
  • 51 Answers
SOURCE: The burner motor stopped working and I can no longer order parts for my heilsa QCPS 28000 pellet stove. Could it just be plugged and if not are there universal parts.
If you are able to disassemble it get the motor out and clean and examine it. If it is a brushed motor Ace Hardware carries brushes for electric motors just take the motor with you to match the brushes. Use electronic components cleaner to clean the motor. It can be found at auto parts stores. Be sure to lubricate the bearings or bushings inside the motor while reassembling it
Posted on Oct 25, 2016
Oct 25, 2016 | Pool & Spa
When I light my pellet stove and push the start button the exhaust fan comes on but the smoke in the stove don't blow out the exhaust. What could be the problem?
Are you sure it is the exhaust fan and not the convection fan or the fresh air fan you hear? If it is the exhaust fan, check for blockage in the exhaust pipe.
Feb 22, 2016 | Whitfield Advantage II-T Service Manual
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
We have a heilsa pellet stove model#QCPS-28000 ,its dropping pellets to fast ,how do I adjust the feed.
  1. SET THE AIR INLET DAMPERS
It is not possible for the manufacture to factory set your stove to work properly without some adjustments. The dampers help control the amount of airflow supplied for combustion.
A damper PUSHED IN all the way, maximizes concentrated air flow to the burn pot. This will maintain a robust fire.
The Auger timing is designed to be run, in most conditions, with the dampers closed.
In some areas/conditions, it mybe necessary to adjust the damper open slighty in order to slow down the flame and allow the pellets to keep pace with the rate of burn. This should be monitored closely to ensure you have the propoer feed rate established. If dampers are opened too much, the rate of burn will be very slow and the pellets will build up.
This setting needs to be fine tuned to according to your location and elevation. It is recommended that you start with the dampers pushed in to start.
Feb 20, 2013 | Northern Tool and Equipment Pellet Stove -...
how to change control board on a heilsa pellet stove
Nov 27, 2011 | Pool & Spa
Nov 22, 2009 | Napoleon Auburn Pellet Stove Heater
Pool & Spa Logo
55 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
