Question about D-Link AirPlus G DWL-G710 Wireless Range Extender
Dlink dwlg710 repeater setup
How to setup
I have many times tried to set up my DWL-G730AP Wireless Router with no success. I have typed the url http://192.168.0.30, but keep getting a list of web pages so I have to use my system without security...
This is the correct address to log on to your router. 192.168.0.30 so i dont know why you are having problems.
Try to reset your router (press and hold the reset button for 30 seconds) and then follow the guide i found here, give the page a minute to load, it is fully illustrated with pictures, so is a little slow to load up
http://www.scribd.com/doc/14641796/DLink-DWLG730AP-Quick-Start-Guide
Aug 13, 2010 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 won't connect to 192.168.0.30
Here is a link to the manual for your DWL-G710.
D-Link manual on page 13 it lists the url entry should be
"http://192.168.0.30" This is a HTTP link not a HTTPS.
Also the address you typed in might be a typo. The IP address should be 192.168.0.30 not 192.168.0.30.
GOOD LUCK!!!!
Oct 18, 2009 | D-Link AirPlus G Wireless Range Extender...
Connection of dlink range extender
I have this unit. Make sure that the network you are repeating is set to stay on a certain channel. The router I was repeating was set to dynamic channels so that it changed based on what channel had less interference. The dlink repeater does not like that and needs the channel to stay the same.
Apr 28, 2009 | D-Link AirPlus G Wireless Range Extender...
Setting up my DWLG710 EXTENDER
You need to give IP add manually to any of ur PC as 192.168.0.31 and than open DWLG setup page on the browser by typing 192.168.0.30. It will bring the setuup page of Extender.. on this page change the IP add from 192.168.0.30 to 192.168.2.50.. it will restart ur extender and make it working in same network... roll back the changes u made to ur PC to connect..
Feb 04, 2009 | D-Link AirPlus G Wireless Range Extender...
Range Extender
Both router and range extender must be setup with the same SSID, encryption key and same FIXED channel assignment.
Jan 22, 2009 | D-Link AirPlus G Wireless Range Extender...
My extender isnt reading the connection tht my router is sending
Firstly I would check you have the latest firmware installed. Follow this link and select the correct revision as shown on the base of your unit. http://www.dlink.co.uk/cs/Satellite?c=Product_C&childpagename=DLinkEurope-GB%2FDLTechProduct&cid=1197319539580&p=1197318962147&packedargs=locale%3D1195806691854&pagename=DLinkEurope-GB%2FDLWrapper - the website also provides you with a little help on hardware tested that CAN be repeated. Please note if your hardware is not listed it does not mean it CAN'T be repeated, it just hasn't been tested.
Dec 15, 2008 | D-Link AirPlus G Wireless Range Extender...
Dwl-2100ap set up propblem
There's quite a bit to know about extending / repeating WIFI signals.
Read about extending a WIFI signal with a Sitecom WL-130 repeater here.
Sep 05, 2008 | D-Link AirPlus G Wireless Range Extender...
DWL_ G710 unit. unable to access 192.168.0.30 in the URL box
IThe Dlink DWL -G710 t's a peice of ****. Throw the friggen thing out and get a real access point.
Jul 24, 2008 | D-Link AirPlus G Wireless Range Extender...
DLink Wireless Extender
  1. move the router,
    the router can be anywhere, as long as it is connected to the modem
  2. reorient the antenna,
    its surprising just how much difference changing the antenna direction has.
  3. ensure the router is broadcasting at 100% power in the router settings page
might not solve the problem, but have worked in the past
Jun 23, 2008 | D-Link AirPlus G Wireless Range Extender...
D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
