How do I adjust tension on an elliptical epic a32e
Nordic track a.c.t. classic elliptical belt tensioner
You have to loosen the underside bolt as well as the 10mm bolt on the side . The 10mm bolt locks the adjuster in place. The underside 16 mm bolt is the adjuster.
Dec 07, 2013 | Nordic Track NordicTrack Treadmill, A2550
Resistance not adjusting
Reading on HSN website, it is b/c this product is junk. Dozens and dozens of reviews stating the resistance is stuck and wont' change.
http://www.hsn.com/products/proform-smart-strider-spacesaver-elliptical/6647352?query=6647352&isSuggested=True
Jan 20, 2013 | Proform Smart Strider SpaceSaver...
Epic el 2980 tension does not change
If the resistance worked before you moved it to where it is now then it's almost certainly a wiring issue. Make sure that each connection that was taken apart is perfect and that each pin is not bent. Make sure that all of the wiring moves freely and there is no pinch. If all of that is correct then it's most likely the resistance motor.
Jun 18, 2017 | Exercise & Fitness
Epic E 950
1= the resistance is adjusted magnetically.
2=the resistance is not adjusted o.k
3=check the bolts that secure the magnet
4=if there are slips, the resistance will slip,adjust
5= test the magnet, with the magnet withe the refrigerator. for attraction +resulpusion. and replace if do not pass the tests.,because they are de-magnetized.
God bless you
Jul 12, 2012 | Epic E 950 Elliptical Resistance...
I have a 6.0 CE eliptical and the tension is not adjusting it seems to be stuck on very difficult
adjust the magnet, tigh the bolts with some wrench. test the magnet with the magnet from refrigerator for to see if is attracted or repeled , change it if necessary.
sincerely. God bless you
Apr 18, 2012 | Proform 6.0 CE Rear Drive Elliptical...
How do I fix my crosstrainer, magnetic resistance has stopped working
This happened to me and I took the wheel mechanism cover off to discover the tension motor cable had come out of it's pulley guide- so there wasn't enough tension left in the cable to pull it away from the wheel- quite an easy fix for me- hope it is the snake for you!
Feb 15, 2012 | Exercise & Fitness
Belt is stopping when i begin to walk on it.
On my Epic you can adjust the belt tension by using an allen wrench in the holes on the end of rails. Tighten 1/4 turn on each side and see how the tension is. Repeat another 1/4 turn if necessary.
Feb 02, 2011 | Epic Overstock T60 Treadmill Treadmills
Tread skips or stops when running
Nov 29, 2010 | Epic Overstock T60 Treadmill Treadmills
Nordic Track elliptical E7: The tension belt came off. It's not apparent how it goes back. Are there diagrams that show the way the belt is attached to the tension cable?
If you are looking at right hand side of unit you have the flywheel next to it adjusting tension plate.If you have your manual handy it will show how to loosen this part so you may loop over the small idler pulley which goes around the much larger pulley wheel if not here is the web page to go to and its on page 21 Hope this nugget will help!
http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=NTEL07808&version=0&company=11&modelName=NORDICTRACK+E7+SV+FRONT+DRIVE+ELLIPTICAL&language=
Apr 06, 2010 | Endurance E7 Elliptical Trainer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
