Question about IBM ThinkPad T30 2366 Notebook
IBM T30 2366 won't operate on battery
This TP operates on AC adaper but shutsdown when removed. I have tried other good batteries but results is the same. Not a battery problem. Any help will be appreciated.
Thanks Matt Simmons
  • 2,229 Answers
First check to see if the battery terminals are clean--and the contacts inside the battery enclosure are clean, also.
If the contacts are clean and working, I'm afraid we have bad news--this would be the motherboard on the computer--as that is where the charging circuit is.
Posted on Jan 23, 2009
0190: critical low battery error
When old IBM Think Pads fail to boot it is usually because the CMOS battery has worn out. It is very easy and inexpensive to replace. Youtube has numerous videos showing how to replace it e.g. https://www.youtube.com/watch?v=8ZI-8Q2j-zQ
Jan 24, 2018 | IBM ThinkPad A30 Notebook
Hello my question? can i operate my IBM r52 thinkpad with out a battery? because the battery will not charge and the thinkpad will not operate with the power cable?
Remove the battery and connect the laptop with the charger and it should operate normally. However, in the absence of battery you won't be able to get backup.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | IBM ThinkPad R52 Notebook
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Hi, I have a 1.5 yr old gateway NV52 laptop that has stayed in sleep mode for two days...I've tried turning it off and cutting back on but it is still in sleep mode...please help
Hi aiomason.
Remove the AC cord and the battery from the notebook. Re-attach battery and AC cord and power up the notebook. This will clear the Ram memory and force the operating system to "Cold Boot", in other words start the operating system loading up from the beginning instead of resuming from Ram the last time it was active. This proceedure should restore your Gateway Notebook to normal operation. Post back your results and good luck.
Jan 24, 2011 | Gateway 450ROG Notebook
I keep the ac adaper in but the charger doesnt
you can see the problem if the battery in not charging or not loading some current. you can do this by unplugging the adapter on the outlet. if the unit turned off then the battery is defective. replace it. now if the problem is the adapter, you can see by removing the battery then plug the adapter to the unit and in the outlet. if the unit didn't turn on, the the adapter is defective. replace it.
Apr 10, 2010 | Acer Aspire 6930-6771 Laptop
Wont boot without password
Unplug the laptop and remove the main battery. Remove the cover for the memory modules and you will also see the CMOS backup battery located there. Unplug it for 10-15 mins, then plug it back in, insert your main battery, ac adapter and boot the system. You will need to reset the system date again once the CMOS is cleared.
Jan 10, 2010 | IBM Computers & Internet
T23 IBM will not operate on battery power & won't charge battery.
The battery has likely been charged one too many times and will no longer hold a charge. Buy a new battery.
Mar 08, 2009 | IBM ThinkPad T23 2647 Notebook
Thinkpad R60 auto-restarted when shutting down
try pulling the battery out for a day running on ac only
Jan 06, 2009 | IBM ThinkPad R60 Notebook
I have IBM LAPTOP thinkpad T43 SERIES. it was working tiil yesteraday. Suddenly it turns switch off. I thought its the problem with AC adapter. I bought a new one. It shows it turn it on but its switch...
It's not necessarily hardware related, can you boot into Bios? If you can try to boot info safe mode, that's F8 for most PCs. I would suspect something with your motherboard drivers, then again it could just be your battery. Not all laptops will operate with the battery out, there is some kind of failsafe to prevent overheating in some, because without a battery the power supply can be fried sometimes.
Hope this helps
Dec 04, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T30 2366 Notebook Logo
71 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
