My Sony cd player CMT-EX1 compact component systemdoor won't open
The CD player has a "door" that opens by lifting vertically so you can insert and remove CDs. When I push the open button, it tries to go up but then seems to get stuck. After a pause, it goes back down.
Is this something I could fix myself? Is it worth taking to some kind of a stereo store to get it fixed or should I just replace the system? (I really like the system and prefer to keep and fix things rather than dispose of them.)
  • 156 Answers
SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Posted on Mar 15, 2007
SOURCE: CD player door won't open
try to dismantle the unit and check the rubber belt on the motor
Posted on Dec 23, 2007
  • 107 Answers
SOURCE: Technics SC-CH515 CD Tray Does Not Stay Open
I DO NOT think that problem related with CD cleaner
3 possibility here
1 The loading belt was lose it can not open fully to reach the switch open when the time limited was out as program design from system control it automatic close
2 The loading gear system out of position 1 tooth
3 Dry joints on switch open and close or connector from CD tray to system control intermittent contact
In any case it require a qualifier Tech from Panasonic to reset the timimg gear or service
I hope that give you some ideas if you need further info or service manual I am willing to help you out
Posted on Dec 10, 2008
SOURCE: Can't close door of CD on Sony CMT-CP1
Mine had the same fault. The CD is being rejected as it could not load up - this is probably because of the CD loading mechanism.
You'll need to unplug and remove the case - 4 screws on the sides and 4 or 5 on the back. Once this is done plug back in (be careful not to touch any live parts inside), load a CD and watch. What you'll probably see is that when the drawer closes the mechanism under the drawer doesn't lift sufficiently. Give it small push when it tries and I bet it then will and the CD will play.
What you need to do to fix this is remove the front panel/PCB and also remove the plastic cover that is screwed above the CD drawer so that you can see more of the topside of the mechanism.
Remove the front panel/PCB by releasing the 2 screws on the bottom and then easing forward. Gentle - as there are pins connecting the front PCB to the side PCB. You should then be able to see a worm drive type arrangement that lifts the lower assembly. This will need regreasing (I used vaseline) with a small stick (I used a Q-tip with the bud cut off). You will probably see where the old grease has been pushed out. Once you've done this, reassemble and operate a good few times to work the grease in.
Done! Mine works fine now after sitting there performing the annoying trick you described for many months!
Posted on Jan 08, 2009
  • 1175 Answers
SOURCE: cd player stuck
It will have to have the coverr taken off and the drawer belt replaced.
Find a stereo repair place.
Posted on Jan 12, 2009
Door won't open.
Hi Walter, this is called the Chucking arm and is made to hold the disc in place when the Pickup assembly is lifted into place. Often times an analysis will show you that the arm is not being lifted due to a lack of grease (Lubrication in the door mechanism) or that the drive parts- motor and a belt are not transferring the energy well enough. I would start with a belt of the correct size and then it may be fixed.
Dec 12, 2012 | Audio Players & Recorders
Sony CDX-CA400 FM/AM Compact Disc Player
The optic inside the CD player may be dirty or damp, this is the part that reads the data from the cd, you can try cd cleaning discs or you may have get an engineer to open it and clean it with an alcohol swab. The optic could also be faulty which will be cheaper to buy a new cd player.
Dec 04, 2009 | Sony CDX-CA400 CD Player
Help - CD won't eject! I press 'Open' on my sony CMT-EX1 system and the CD moves backwards as though it's going to eject but then it stays there, unreachable. Then the display begins to switch between...
I have the same problem and it's due to dirt!
I'm going to try using compressed air, but -
this definitely works:
:) Seriously:
tilt the cd player to a 45 degree angle (flat, basically - as if they tray were horizontal.)
I had my player for 10 or 12 years, and this problem is only coming up now. My house gets very dusty.
Also - vertical load disc players are hard to clean. X_X (inside the disc tray)
I love this stereo too!
I don't want to have to go out and buy another stereo!
Oct 16, 2009 | Sony CMT-EX1 CD Shelf System
Need remote for sony cmt-ex1 any one help pleas 1st time on
Parts store shows this remote as #141861411 but not avail. MCM Electronics has that part number as 1-418-614-11 (RM-SCEX1) under thier order number 32-20405 for $13.80. You may wish to consult your owners manual to verify the number of the orig remote provided before ordering just to be sure.
Jul 16, 2009 | Sony CMT-EX1 CD Shelf System
Can I connect my computer to my Sony CMT-EX1 CD
stereo headphone jack from pc through to AUX, if on your system, via twp rca plugs
Jul 01, 2009 | Sony CMT-EX1 CD Shelf System
The cd draw has locked it self dont know how to
there will be a small hole on your drive.... insert a safety pin in will unlock...
May 16, 2009 | Audio Players & Recorders
Cd player not working
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
Sony cmt-ex1 CD verical loader
If your two speakers are working,if ok ,then the problem is in power amp section ,the IC chip there is already defected .changed that IC so it works normal again and some reheating works in power amp.section...
rate me as FIXYA
Jul 03, 2008 | Sony CMT-EX1 CD Shelf System
Laser does not read cd. says no disk therefore cd will not start spinning to pay
has bad tray cd rom would be hard to get this part also is it under warenty can u return it
Feb 04, 2008 | Sony CMT-EX1 CD Shelf System
152 people viewed this question
