Question about Eureka 3276AZ Pet Lover Bagless Upright Vacuum
Eureka multicyclonic brush roll not spinning - Eureka 3276AZ Pet Lover Bagless Upright Vacuum
yeroc
  • 397 Answers
SOURCE: Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Posted on Jan 20, 2008
reddevil6
  • 1673 Answers
SOURCE: Eureka Uno brush not spinning
There are 2 or 3 screws on the top to take out and the top cover will come off. Belt is #61120A U long life, brush roll if you need it is #62365-2. If the brushs look ok and the ends turn freely, then it is probably ok. The belt goes around the brush roll then up to the motor shaft.
Posted on Mar 02, 2008
Agent Don
  • 310 Answers
SOURCE: brush roll not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=453845
Brushroll not spinning
Posted by vistaloopy on Mar 19, 2008
I have a Eureka Bagless Optima 431 Lightweight Upright that is not working. I took it apart to clean the brushroll and have tried to put it back together several times, but the brushroll will not spin anymore. Maybe I'm putting the belt in the wrong spot? Where can I find a diagram or something?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. You have only 2 choices, the belt is either side driven belt or the belt is a center driven belt and the brushroll has one side that is for the belt and the side driven brushroll and the motor pulley must be in line in order to work properly, you may want to check the bearing holders, some vacs will mark the ends with words like NEW or USED and both have to be identical in order to fit right. Once you have the brushroll out it should spin if you set it on it’s side and if that happens you are OK, then watch the ends of the brushroll. Align the end with the motor pulley, B4 install the belt place the belt on the pulley side and install the brushroll. Then once the brushroll is in and spins properly, and then you can use a belt puller and stretch the belt onto the motor pulley and then track it in a straight line. If you need further help please feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 10, 2008
SOURCE: Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
Posted on Jan 06, 2009
galati2k
  • 281 Answers
SOURCE: Eureka boss 5893A brush roll does not work
you have to prss the pedal and lean it back the brush roll wil enguage
Posted on Apr 23, 2009
Why my eureka vacuum makes a lot of noise?
require some greasing/oil in bearings
Apr 07, 2017 | Eureka Vacuums
My eureka multicyclonic vaccuum isn't spinning or picking up any dirt, what do I do?
Try open the bottom cover where the motor is located. It seems the the power belt is broken. Guides and Manuals Eureka
Apr 13, 2014 | Eureka Vacuum Cleaners; AIRSPEED One...
Have a Eureka "the boss" smartvac, won't pick up anything when I try to vacuum carpet. Any suggestions on how to fic this problem?
1st) make sure your yellow dial at the top by handle is in floor position
2nd) make sure your brush roll spins when handle is reclined in operating position. (disengage brushroll control by flipping the "switch" towards you)
3rd) check belt to make sure it is not broken
4th) check the brush roll for debris caught in it
5th) check lower hose
Aug 12, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
My boss model 5892 brush will not roll
This unit has a reset button on the side of the hood. Recline handle, turn power switch on, pressing down in carpet mode, press reset buttonon the side of the hood, the brush should turn on.
May 01, 2010 | Eureka 5856BVZ Boss Bagless Upright...
I have a Eureka 5902AVZ and the brushroll does not work. when i remove the belt, which is not torn nor worn out, the motor spins perfectly fine. Though when i put the brushroll back into place, it shows...
Hi and welcome to Fixya. I am Kelly.
You have correctly identified the problem as the brush roll itself.
There is a bearing under each end cap of the brush roll. You can gain access to the bearings usually by gripping the browah roll end caps and rotate the caps in opposing but loosening (ccw rt / cw left) directions.
Many times I have found that there is just a mass of hair under the end cap that functions like a brake. Clean it up really well on under BOTH end caps.
Do a spin test by putting the end caps back on (Hold it horizontal) and rotating the brush roll with your thumbs. It should spin freely.
If it feels like there is still friction then your probably going to have to take the brush roll with you down to the nearest vacuum cleaner repair / supply shop and get 2 new bearings. Most shops will install the NEW bearings for you if you have the brush roll in hand. It is a much cheaper fix than the brush roll itself.
(buy a new belt too!)
Take care
Kelly
http://www.eureka.com/servlet/ListParts?model=5902avz
Feb 10, 2010 | Eureka 5902AVZ Bagless Upright Vacuum
Brush is not rolling. I have checked the belts
Unhook the belt see if the motor shaft turns by itself. If it doesn't then the motor is the issue. If it runs then its probably the belt or the brush roll.
Dec 01, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Looking for Eureka belt 70646A for a Eureka The Boss upright
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
Mar 08, 2008 | Vacuums
Mar 01, 2008 | Eureka Uno 2998AZ Bagless Upright Vacuum
Eureka 3276AZ Pet Lover Bagless Upright Vacuum Logo
646 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
