Question about IBM Thinkpad I1400 2621 Planar TV (10L1537) Motherboard
Thinkpad i1400-2621-480 bios does not recognise my new hard drive
My old trvelstar hard drive had died .so i took out the drive anrd replaced with initialised and( formatted by adapter on my desktop disk manager). but my ati bios v3.8 r01-a2i, can not see my healthy seagate drive.what could be the problem? it keeps asking for system diskette. after usinf system diskettes, it can,t start because ,hard drive is not availble.help me.
The hard drive has to be fdisked and formatted on the laptop to function. If you don't have an internal floppy, I use an external USB drive plugged into the laptop to do the job.
Posted on Jan 23, 2009
My laptop died so i bought a new one. i took the hard drive out and put it into a hard drive enclosure and have connected it to my new one by usb. my new laptop doesnt recognise that anything is there...
You may have to change the settings on the old hard drive. Keep in mind, the old hard drive was a Master. Since there's already a Master in your new machine, you may have a conflict. Look for jumper settings on the old hard drive to set it to Slave. You can also go into your BIOS and assign the older hard drive as a slave.
Sep 08, 2011 | Computers & Internet
My PC is working fine, when my mouse starts lagging and a blue screen pops up, telling me to reboot my computer. so I do, and when it comes on, a screen comes up saying American Trends and some other...
The message you are seeing (ami trends) is the 1st stage of the netbook booting (the bios), this checks that all the system components are present in a sequence.
From what you are describing, it looks as though the hard drive has slowly been failing and this would account for the lagging mouse. The Bios error message "hard disc error" confirms that the bios has not been able to detect the hard drive, which could mean that the drive has failed, the drive controller has failed, or, (possibly) this is virus related. Pressing F1 to resume will achieve nothing, as this is a sort of skipping step that ignores the problem.
Before going into the stages below, try to access the bios (press F2 just as it powers on), look for the screen which lists the boot order and drives attached, see if it "sees" the hard drive (primary master) and that it is selectable. If so, reboot and see if it now detects it. Sometimes removing and reinserting the drive is enough to get it to be recognised
If it then works, worth virus scanning the drive to be on the safe side
Fixing the problem:
Firstly, you need to see if the hard drive has indeed failed, the best way is to substitute the hard drive with another one known to be good. If this is recognised in the bios, than this has most likely been the issue. You will need to reinstall windows (external CDrom and windows OS needed)
Secondly, if the hard drive is not detected by the bios, the fault lies in the hard dive connection ( check the connection from the hard drive to the motherboard, make sure it is firm and not loose, sometimes even a loose fitting drive will not be recognised). If it still is not recognised then the problem lies with the motherboard and will possibly need specialist repair
Apr 20, 2011 | ASUS Eee PC 1000HE Netbook
My hard drive died in my HP pavilion 9795c. I replaced the hard drive, inserted the recovery cd and it says error loading operating system. I used a full version of xp pro with the same result. In setup...
I would suggest you pull the new hard drive out to make sure you've got the jumpers set correctly. Match them up with what you had on the old drive. Master / Slave / CS (cable select)
Once that's corrected you should be able to boot into the recovery cd so long as you set the boot options up correction in the bios.
Let me know if you get stuck.
Jan 22, 2011 | HP Pavilion 9795C PC Desktop
HArd drive issue. Self diagnostic desnot recognise the hard drive
Was the replacement hard drive a new one? If not it will have to be formatted first
Jul 18, 2010 | HP Computers & Internet
Does not boot error says no hard disk. I took out the old hard disk and installed a new one.
Make sure that the hard disk you put in is one supported in size by the bios of the laptop.
Jun 18, 2010 | IBM ThinkPad T20 2647 Notebook
I have a ibm thinkpad t20 and when the internal battery died the computer started asking for a password when booting up. I know how to reset the password on a desktop but this thinkpad has me stumped. Can...
the default BIOS password for this model is merlin but if that doesn't work you have a hard drive password set and may for lack of a better term be screwed. You can try zero wiping the harddrive from another system assuming you have the right cabling/adapters.
If the Hardrive is locked but the BIOS password works you can also acquire a new hard drive cheaper than a password cracker in most cases.
Hope this helps FixYa,
Chris
May 15, 2009 | IBM ThinkPad T20 2647 Notebook
Take Took Long Entering Bios Setup
You should get some diagnostic tools (like Hiren's BootCD, PC DR., or Microscope) and run a system scan, paying specific attention to the RAM and the Hard Drive, but this sounds more like a Hard Drive issue than a RAM issue, but do both just to make sure.
Apr 01, 2009 | IBM ThinkPad R40 2722 Notebook
Operating system not found
Unfortunately the mot common reason for 'operating system not found' is a failed or corrupted hard drive. You need to go into your BIOS menu and see if your hard drive is recognized by the computer. When booting up push F1 and enter the BIOS menu. Go to the menu item for boot up or start up and see if your hard drive is recognized. If your hard drive is recognised then it may be salvageable by booting from a recovery disk or reinstalling windows from a CD. If the drive is not recognised in the BIOS, you have a dead hard drive or maybe just a bad connection. More help can be found on the Lenovo website site and the Forum at that site.
http://lenovo.com/planetwide/select/selector.html
http://forums.lenovo.com/lnv/board?board.id=T_Series_Thinkpads
Nov 28, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
166 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
