Question about Zyxel P660HW-D1 Router
Zxyel router Can't get Wirless to work
I have a zxyel router and when I connect via the cable I get internet access. However, I can't connact with wireless. I can't pick up any new wireless routers outputting?? any sugesstions?
  • mrjae Jan 24, 2009
    Thankyou for your response but still no luck. Steps 1 and 2 I have definitely checked. Step 3 I have tried but I cannot see any Hide SSID checked box. I did see the SSID information. The only button I have is the apply button and I don't seem to be able to change anything else??
  • eecom May 11, 2010
    Hello...there could be many reasons for this.
    I understand from your other posting that when you go to 'View Wireless networks', your own is not there? Yet your wireless LED is lit on the the router, and you can obtain internet when you connect via cable?
    If that's the case, and I've understood the problem correctly, here are some basic troubleshooting steps to begin with:
    1. While diagnosing wireless connection problems, bring the laptop as close as possible to the router. This helps to rule out physical obstructions and/or wireless interference, which can block a signal.
    2. Next, if there is a button on the laptop to enable your wireless connection, double check that it is switched on.
    3. If you don't 'see' your own network in your 'available wireless networks', check whether your SSID (network name) is broadcasting.
    To do this, connect to the router using a wired (ethernet) connection. Type the router IP address into a web browser, eg: http://192.168.1.1 . At the prompt, enter the password: 1234 or whichever password you have set.
    I think the SSID settings are found under Network (left hand menu) > Wireless LAN. Under the General tab, check to see if 'Hide SSID' is checked: if so, uncheck it, click 'Apply', and close the screen. Return to the laptop and try the wireless connection again: see if your network name now appears.
    These are only basic steps to start you off. If they don't help, or you need more information, please come back to Fixya.
    If needed, you can pick up a user manual from Zyxel which may give more details.
    Good luck....
  • 104 Answers
Hi again….thank you, I see!
The Zyxel manual is very large (350+ pages); it has several versions, and the user interface is quite complex. I was expecting (hoping) you might see the following screen - p108 of the manual I was looking at.....
- but maybe another option has to be selected at login – eg ‘Advanced’?
I’ll leave that one with you for the moment, but it’s worth noting that when you find it - or its equivalent - ‘Active Wireless LAN’ box must be checked, or wireless will not work.
In the meantime, another troubleshooting step is to check the status of the wireless adapter, on the laptop. If you have not done this already, here is a guide:
1. On your laptop, pull up the Device Manager (if using Windows). One way is to go to Start > Run (for Windows XP only) > type devmgmt.msc in the box you see, and click OK.
2. You should see the Device Manager. Next to Network Adapters, click any ‘+’ you see to locate the Wireless Network Adapter. Are there any unusual symbols there, such as a red cross, or yellow exclamation mark?
If so, this suggests a problem with the wireless adapter. For example, a disabled adapter will show a red cross (right click to select 'enable').
There is more troubleshooting you can do within Device Manager, such as updating the device driver - but it's good to check for obvious problems first.
Apologies if you have checked all this already, but this is where I would start, given the problem you describe.
If all seems well with the Wireless Network Adapter, and the router is broadcasting its SSID - or if you have problems with troubleshooting - please come back to Fixya.
Posted on Jan 25, 2009
  • eecom Jan 25, 2009
    Many thanks for the feedback. I don't know if you have managed to connect yet?
    If you have not found whether or not your SSID is broadcasting, you could try manually connecting to your wireless signal anyway. This link gives you a quick guide to how to do this is Windows XP -and here's one for Vista.
    If you still cannot connect, this would suggest your wireless is not broadcasting at all, or there may still be a problem with the wireless network adapter.
Can not recived wirless internet on my pc
> Is your pc capable of wireless connectivity
> If yes connect via cable and check if it is working
> If yes provide info on wifi device
> If no you may have to check the router
Sep 17, 2013 | Linksys SMALL BUS VPN ROUTER W/...
I can not connect wirless router
check the cable of the router it may not be inserted properly. If the problem still exist unplug the router then plug it again to refresh the configuration...then try to connect again. If still not working the possible cause will be the ISP or the internet subscriber provider...signal maybe too low to access the internet
Sep 16, 2011 | Computers & Internet
Can connect to DLINK adsl2 router via wirless but
Make sure your LAN connection is not disabled,
make sure that you are getting a valid IP address form the router
If you need commands for this let me know, also which OS are you using
Jan 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
Wanting to connect 2nd computer to internet, have router
If it is by wirless you will need to adjust the wirless adapter setings by going to your network conecsions click on the wirless conecsion and confiqir it to use stronger setings it should have a descripsion for all stings. I hope this will help you. Also do not forget to vote.
Jan 17, 2009 | Gateway Cable/DSL Router - 4Port [ Belkin...
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
Connection
You should not need the CD for having a PC to access the internet. If you have the manual - Look at accessing the router with http://192.168.0.1
Not sure what you are trying to do... Are you trying have your sister be able to access the internet, through wireless? I'm sure I can help with some more info.
G'luck
Oct 24, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Wirless Setup
have you opened run, typed in cmd ,then ipconfig to make sure this is your ip addy
Nov 29, 2007 | Linksys Wireless-G WRT54G Router
Zyxel P660HW-D1 Router Logo
200 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
