Question about RCA CC617 VHS-C Analog Camcorder
RCA CC617 I just bought a used RCA cc617 vhs camcorder. The view finder is black. But you can hook it up to the tv and it will record and play back. Can anyone help with this problem.
Had the same problem took mine apart and found the ribbon cable going to the viewer was cracked and broken probably because of the flexing of the cable during adjustments. Not fixed yet.
Posted on Oct 17, 2008
    Problem Solver:
  • 19 Answers
Probably the lcd screen is broken (the one that you can see through the veiw finder) if this is the case it is not reasonably fixable. Otherwise it may be a connection that is broken and it is not getting any feed. If you give it a little tap and it comes to life breifly, this is probably the case. You can take it to a small electronics repair shop and they will let you know if its worth fixing or just using as is.
Posted on Jul 09, 2007
SOURCE:
I have a Sony Handycam Vision CCD-TRV65 and I want to convert the video to DVD to a VHS, how do I do that?
using the RCA outputs and an RCA patch cord, Input the signal into a VCR line input. Play the video back on the camcorder and using a good, high quality VHS tape insert in VCR and press record
Jan 17, 2011 | Sony Handycam CCD-TRV87 Camcorder
No video on the camera viewfinder or miniscreen
At seventeen years old, it is well beyond the expected lifespan of any domestic camcorder. Replace it.
May 23, 2017 | RCA CC4393 VHS Analog Camcorder
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Nothing but a blue screen...ugh!
buy a cleaning cassette and play three times it will work well.
Oct 12, 2008 | JVC COMPACT VHS-C CAMCORDER
Can't view DVD's burned from the tv on a DRC8335 RCA DVD recorder
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
Jan 02, 2008 | RCA DRC8335
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Picture rolls on playback
Possible causes: the sync signal head is not recording, there is a mismatch between the capstan motor speed and the video head speed, or one of the sync circuits has a fault. Typically, if the picture rolls up or down, it's a vertical sync problem. A horizontal sync fault or tracking mismatch will cause the picture to tear sideways.
Try cleaning the sync head (one of two heads separate from the video head drum; the other is the audio track head), but don't be surprised if doesn't solve the problem.
Feb 25, 2018 | RCA CC617 VHS-C Analog Camcorder
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Video Cameras Logo
329 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
