Question about Sewing Machines
Adjust bobbin tension on Singer Model 2005
Despite having the upper tension set as high as it goes, I still get looping underneath. How do I loosen the bobbin tension? There is nothing in the owner's manual. I'm assuming Singer doesn't want end users fiddling with it, but something has to be done. This machine has had 3 upper tension assemblies which work for a little while and then the problem re-occurs. I got so frustrated, I bought another brand and use this machine as backup when my ''good'' machine in unavailable. It's a shame because the 2005 makes excellent buttonholes when it is working right.
    Scholar:
  • 65 Answers
So you have adjusted the bobbin case screw tight?
(the shuttle that holds the actual bobbin)
It sounds like your needle is to fine or heavy for the material or thread you are using. I have been finding lately all threads are NOT created equally. Some are down right garbage (the cheap ones especially)
You may also want to check your bobbin case, it may be damaged in some way and causing this issue.
http://www.singerco.com/support may also be able to help.
(they want us to contiu
Posted on Jan 24, 2009
When sewing with straight stitch, I get loops underneath. I've changed bobbin, rethreaded, cleaned lint, etc. still making loops on under side.
You may need to adjust the tension knob for the thread . Usually located above the needle . screw it in a little at a time or perhaps it has a number scale if so increase to a higher number a little at a time till the stitches become correct.
Dec 18, 2016 | Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
New singer plus one.....constantly stopping with message top thread broken (which it is not) but there is a nest of thread from the spool underneath...have rethreaded from spool and bobbin # of times
bird nesting of the bobbin thread is a result of the needle thread tension not tight enough
increase that tension up and the message may be eliminated
Nov 20, 2016 | Singer Sewing Machines
My singer sewing machine 7102 is looping the top thread underneath
Upper thread looping under the fabric is usually a sign that the thread is not seated in the tension disk or it is threaded incorrectly. FIRST, make sure you have a brand new needle in it. Remove the upper thread completely. RAISE the presser foot and rethread from the beginning. Verify that the thread pathway is correct. Also check that the upper tension is not set too loose.
Apr 04, 2016 | Singer Sewing Machines
I have singer 4423.The needle thread in bunching up in the bobbin case and not sewing! When it didn't pick up bobbin thread I loosened bobbin tension which fixed that problem.
Sounds like bird nesting.
Install a brand new needle.
Remove the upper thread completely. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly according to the manual.
Set the upper tension to the midway point between high & low numbers. Retest on a scrap of fabric.
P.S.--once you get the upper tension correct, you may find you will need to readjust the bobbin tension.
Also make sure that your needle, thread, and fabric are compatible.
All About Needles
Feb 15, 2016 | Singer Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
Top thread too tight. Bobbin thread too loose. Bobbin thread bunches up underneath material. The feeder teeth can not feed material through
first thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. .
Nov 03, 2015 | Sewing Machines
Advice on how do I adjust tension
I don't have a Janome, but in general
if your seam has extra loops at the top
looks like ^-^-^-^
loosen the upper tension a bit and tighten the bobbin tension a bit.
If the extra loops are at the bottom
sort of like \/-\/-\/-
do the opposite - tighten the upper tension a bit and loosen the bobbin tension a bit.
The upper tension is easy; it's usually a dial with +/- numbers. The bobbin may be more difficult. For mine, it's a screw on the side of the bobbin case. A web search seems to indicate Janome is the same.
Practice on scraps of the same weight and use the same thread you're using on your project until you get the tension right.
good luck
Oct 03, 2014 | Janome Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Sewing Machines Logo
82 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
